Jabra Micro USB Cable 1.5M
Quicklinx: 8GQNWS00 Mfr#: 14201-26
Length: 1.5m
£25.15 ex VAT
£30.18 inc VAT
Marketing description is not available.
  • Efficient connectivity
    Equipped with a USB cable featuring a 4-pin USB Type-A connector on one end and a 5-pin Micro-USB Type-B connector on the other, this Jabra headset ensures a reliable and easy connection to a wide range of devices. The dual male connectors facilitate seamless audio transmission, making it ideal for both professional and personal use.
  • Versatile compatibility
    The inclusion of both USB Type-A and Micro-USB connectors enhances the headset's compatibility, allowing it to work effortlessly with a multitude of devices. Whether connecting to a computer, smartphone, or tablet, users can expect a stable and consistent audio experience without the need for additional adapters.
Jabra - USB cable - USB to Micro-USB Type B - 1.5 m
USB cable
Length
1.5 m
Connector
4 pin USB Type A - male
Connector (Second End)
5 pin Micro-USB Type B - male
Engage 55 Mono; GO 6430, 6470; PRO 9460, 9460 Duo, 9460 NCSA, 9465 Duo, 9470, 9470 NCSA
USB cable
Length
1.5 m
Connector
Jabra Engage 55 Mono , Jabra GO 6430, 6470 , Jabra PRO 9460, 9460 Duo, 9460 NCSA, 9465 Duo, 9470, 9470 NCSA
Length: 1.5m
Brand: Jabra
