GN Netcom's vision is to be the world's leading provider of communications solutions that enable people to communicate more easily and effectively. GN Netcom's product portfolio covers a wide range of products for a variety of different applications and environments.
Enhanced clarity
Designed specifically for headsets, this microphone windscreen helps reduce unwanted background noise, ensuring your voice is heard clearly during calls and recordings. -
Convenient packaging
With a packaged quantity of 10, users can easily replace windscreens as needed, ensuring optimal performance and hygiene over time.
- Jabra - windscreen for headset
- Product Type
- Windscreen
- Packaged Quantity
- 10 (specifications are for single item)
- Intended For
- Headset
- Designed For
- Jabra GN 2000 Duo Flex. NC, GN 2000 Duo. Omni, GN 2000 Flex Mono, GN 2000 Mono. Omni, GN 2000 NC Mono, GN 2000 Sound Tube Mono, GN 2000 Standard Mono Flex, GN2000, GN2000 Duo, GN2000 NC Duo, GN2000 Sound Tube Duo
- Packaged Quantity
- Product Type
- Windscreen
- Intended For
- Headset
- Designed For
