Jabra LINK Electronic Hook Swith Cable
Quicklinx: 7T9NWS00 Mfr#: 14201-32
Type: Cable
£40.53 ex VAT
£48.63 inc VAT
Enjoy wireless freedom and get remote call control on your wireless headset from a wide range of Nortel/Avaya deskphones using an Electronic Hook Switch (EHS) cord. Answer or end calls, mute the microphone and adjust volume when you are away from the desk.
  • 150 Metres Wireless Freedom
    The Jabra Link 14201 series puts the freedom and convenience of wireless communication in everyone's reach. You can now walk and talk up to 150 metres away from your deskphone. Answer calls, multitask and move around on your terms.
  • Easy to deploy
    The Jabra Link 14201 series is optimised for use with all leading deskphone systems that provide EHS functionality and enables plug-and-play remote call control functionality with your cordless headset.
  • Remote Call Control
    Answer and end calls, adjust the volume and mute your call on the Jabra wireless headset with seamless integration between your deskphone and headset. The remote call control gives you the power to multitask and be productive.
Jabra LINK - electronic hook switch adapter
Electronic hook switch adapter
Avaya 1120E, 1140E, 1165E, IP Phone 1140E; Jabra GN9330e, GN9350, GN9350e; GO 6470; PRO 9450, 9460, 9465, 9470; Nortel IP Phone 1165E
Avaya 1120E IP Deskphone, 1140E IP Deskphone, 1165E IP Deskphone, IP Phone 1140E , Jabra GN9330e, GN9330e USB, GN9330e USB for Microsoft Office Communicator 2007, GN9350, GN9350 for Microsoft Office Communicator 2007, GN9350e, GN9350e for Microsoft Office Communicator 2007 , Jabra GO 6470 , Jabra PRO 9450, 9460, 9460 Duo, 9460 NCSA, 9465 Duo, 9470, 9470 NCSA , Nortel IP Phone 1165E
Type: Cable
Brand: Jabra
