Jabra LINK Electronic Hook Switch Adapter Cable
Quicklinx: 84M1WS00 Mfr#: 14201-35
Recommended Use: Accessory
Connectivity: [N/A]
Earcover : [N/A]
£32.88 ex VAT
£39.45 inc VAT
Enjoy wireless freedom and get remote call control on your wireless headset from a wide range of Avaya deskphones using an Electronic Hook Switch (EHS) cord. Answer or end calls, mute the microphone and adjust volume when you are away from the desk.
  • 150 Metres Wireless Freedom
    The Jabra Link 14201 series puts the freedom and convenience of wireless communication in everyone's reach. You can now walk and talk up to 150 metres away from your deskphone. Answer calls, multitask and move around on your terms.
  • Easy to deploy
    The Jabra Link 14201 series is optimised for use with all leading deskphone systems that provide EHS functionality and enables plug-and-play remote call control functionality with your cordless headset.
  • Remote Call Control
    Answer and end calls, adjust the volume and mute your call on the Jabra wireless headset with seamless integration between your deskphone and headset. The remote call control gives you the power to multitask and be productive.
Jabra LINK - electronic hook switch adapter
Electronic hook switch adapter
Avaya one-X Deskphone Edition 9610, 9620, 9620C, 9620L, 9630, 9630G, 9640, 9640G, 9650, 9650C, 9670G; one-X Deskphone Value Edition 1603, 1603-I, 1603SW, 1603SW-I, 1608, 1608-I, 1616, 1616-I
Volume control
2 years
Avaya one-X Deskphone Edition 9610 IP Telephone, 9620 IP Telephone, 9620C IP Telephone, 9620L IP Telephone, 9620L IP Telephone w/o faceplate, 9630 IP Telephone, 9630G IP Telephone, 9640 IP Telephone, 9640G IP Telephone, 9640G IP Telephone w/o faceplate, 9650 IP Telephone, 9650C IP Telephone, 9670G , Avaya one-X Deskphone Value Edition 1603, 1603-I, 1603SW, 1603SW-I, 1608, 1608-I, 1616, 1616-I
Connectivity: [N/A]
Earcover : [N/A]
Brand: Jabra
Stock Status: In stock
