The Jabra LINK 14201-41 enables remote Electronic Hook Switch Control (EHS) with Jabra wireless headsets. Jabra wireless headsets with EHS functionality boost productivity as they provide the users with the ability to answer and end a call, while away from their desk.
Enhanced control
Equipped with a mute switch and volume control, this headset adapter allows for seamless adjustments during calls, ensuring clear communication without interruptions. -
Versatile compatibility
Designed specifically for VoIP phones and wireless headsets, this adapter offers a reliable connection, enhancing your device's functionality and audio performance.
- Jabra LINK - headset adapter for wireless headset, VoIP phone
- Product Type
- Headset adapter
- Intended For
- Wireless headset, VoIP phone
- Length
- 86 cm
- Designed For
- Cisco Unified IP Phone 8941 Slimline, 8941 Standard, 8945 Slimline, 8945 Standard
- Product Type
- Headset adapter
- Intended For
- Length
- 86 cm
- Volume control, mute switch
- Designed For
