Better connection, better UC performance
For a headset to be UC-certified, most UC vendors require superior connectivity, which is guaranteed by a Bluetooth adapter. Jabra Link 390 is available in two variants, one for Microsoft Teams-certified devices and one for UC-certified devices. So whatever platform you're using, you can be sure you're getting the gold standard in connectivity. -
The freedom to roam
You need a stable wireless connection if you want to be able to walk and talk. Without a Bluetooth adapter, your device's connection might get patchy over a relatively short distance. Jabra Link 390 is discreet and flexible, giving you maximum mobility and freedom of up to 30m / 100ft wireless range. Enjoy multiple device pairing and a design that doesn't add extra load to your laptop. -
Maximum control, minimum effort
Technology is better when it's easy to use. Jabra Link 390 is plug-and-play – no need to install separate software drivers. It's easy to manage through Jabra Direct, so you can push over-the-air software updates to all users in an instant, and there's even a handy LED light which tells you the status of the headset, whatever computer or software you're using. -
Sound that won't let you down
Whether you're sitting at your desk or not, your sound quality shouldn't change. With A2DP Bluetooth 5.3 profile and HD Voice, Jabra Link 390 gives you rich sound quality, even when you're away from your computer, allowing you to enjoy crystal-clear conversations and stream music in incredible HiFi sound quality. Link 390 keeps your headset sounding great, whatever you're doing.
- Jabra LINK 390a MS - network adapter - USB-A
- Network adapter
- Form Factor
- External
- Interface (Bus) Type
- USB-A
- 1.602 cm x 2.126 cm x 0.47 cm
- 1.713 g
- Data Link Protocol
- Bluetooth 5.3 LE
- Capacity
- Simultaneous connections: 2
- System Requirements
- Apple MacOS, Linux, Microsoft Windows
- 2-year warranty
- Network adapter
- Form Factor
- External
- USB-A
- Connectivity Technology
- Wireless
- Bluetooth 5.3 LE
- Bluetooth Profiles
- Hands-Free Profile (HFP), Advanced Audio Distribution Profile (A2DP), Audio/Video Remote Control Profile (AVRCP)
- Capacity
- Max Range Open Space
- 30 m
- Status Indicators
- Status
- ABS housing, PC/ABS housing
- Software Certification
- Certified for Microsoft Teams
- Plug and Play
- OS Required
- 1.602 cm
- 2.126 cm
- 0.47 cm
- 1.713 g
- Shipping Width
- 6 cm
- Shipping Depth
- 1 cm
- Shipping Height
- 8 cm
- Limited warranty - 2 years
- -10 °C
- 60 °C
