Jabra LINK 390a USB-A MS BT Adapter
Quicklinx: J5WDWS00 Mfr#: 14208-41
30 In Stock
£82.71 ex VAT
£99.25 inc VAT
Engineered to enhance Bluetooth connectivity from your Jabra device to your computer.
  • Better connection, better UC performance
    For a headset to be UC-certified, most UC vendors require superior connectivity, which is guaranteed by a Bluetooth adapter. Jabra Link 390 is available in two variants, one for Microsoft Teams-certified devices and one for UC-certified devices. So whatever platform you're using, you can be sure you're getting the gold standard in connectivity.
  • The freedom to roam
    You need a stable wireless connection if you want to be able to walk and talk. Without a Bluetooth adapter, your device's connection might get patchy over a relatively short distance. Jabra Link 390 is discreet and flexible, giving you maximum mobility and freedom of up to 30m / 100ft wireless range. Enjoy multiple device pairing and a design that doesn't add extra load to your laptop.
  • Maximum control, minimum effort
    Technology is better when it's easy to use. Jabra Link 390 is plug-and-play – no need to install separate software drivers. It's easy to manage through Jabra Direct, so you can push over-the-air software updates to all users in an instant, and there's even a handy LED light which tells you the status of the headset, whatever computer or software you're using.
  • Sound that won't let you down
    Whether you're sitting at your desk or not, your sound quality shouldn't change. With A2DP Bluetooth 5.3 profile and HD Voice, Jabra Link 390 gives you rich sound quality, even when you're away from your computer, allowing you to enjoy crystal-clear conversations and stream music in incredible HiFi sound quality. Link 390 keeps your headset sounding great, whatever you're doing.
Jabra LINK 390a MS - network adapter - USB-A
Network adapter
External
Interface (Bus) Type
USB-A
1.602 cm x 2.126 cm x 0.47 cm
1.713 g
Bluetooth 5.3 LE
Simultaneous connections: 2
Apple MacOS, Linux, Microsoft Windows
Network adapter
External
USB-A
Wireless
Bluetooth 5.3 LE
Bluetooth Profiles
Hands-Free Profile (HFP), Advanced Audio Distribution Profile (A2DP), Audio/Video Remote Control Profile (AVRCP)
Max Range Open Space
30 m
Status Indicators
Status
ABS housing, PC/ABS housing
Software Certification
Certified for Microsoft Teams
Plug and Play
1.602 cm
2.126 cm
0.47 cm
1.713 g
Shipping Width
6 cm
Shipping Depth
1 cm
Shipping Height
8 cm
-10 °C
60 °C
Brand: Jabra
