The Jabra LINK 265 gives you an effective way to train your agents. Unique USB Y-training cable connects two Jabra Quick Disconnect (QD) headsets to one PC, so supervisors can either stay muted or join the conversation. Simple call controls and programmable soft buttons enable fast customisation for individual preferences. Control of Noise at Work compliant.
                Flexible configuration possibilitiesThe Jabra Link 265 can be configured to suit your work environment. Optimised for Jabra PC Suite and Jabra Express, you can configure the settings to suit your individual needs.
                Prevent stress and hearing injuriesReduce the number of sick days and increase employee retention. Jabra Link 265 delivers acoustic shock protection and is compliant with EU Control of Noise-at-Work legislation (Directive 2003/10/EC).
- Jabra LINK 265 - headset adapter
- Cable
- Headset adapter
- Connector
- USB - male
- Connector (Second End)
- 2 x Quick Disconnect
- Answer/end button, in-cord volume control, mute switch, Digital Signal Processing (DSP) technology, SafeTone technology
- Cable Type
- Headset adapter
- Connector
- 4 pin USB Type A - male
- Plug and Play, Directive 2003/10/CE
