Jabra LINK 265 QD To USB Training Cable
Quicklinx: 9FRXWS00 Mfr#: 265-09
Type: Cable
More than 50 In Stock
£79.60 ex VAT
£95.52 inc VAT
The Jabra LINK 265 gives you an effective way to train your agents. Unique USB Y-training cable connects two Jabra Quick Disconnect (QD) headsets to one PC, so supervisors can either stay muted or join the conversation. Simple call controls and programmable soft buttons enable fast customisation for individual preferences. Control of Noise at Work compliant.
  • Flexible configuration possibilities
    The Jabra Link 265 can be configured to suit your work environment. Optimised for Jabra PC Suite and Jabra Express, you can configure the settings to suit your individual needs.
  • Prevent stress and hearing injuries
    Reduce the number of sick days and increase employee retention. Jabra Link 265 delivers acoustic shock protection and is compliant with EU Control of Noise-at-Work legislation (Directive 2003/10/EC).
Jabra LINK 265 - headset adapter
Cable
Headset adapter
Connector
USB - male
Connector (Second End)
2 x Quick Disconnect
In-cord volume control, answer/end button, mute switch, Digital Signal Processing (DSP) technology, SafeTone technology
Cable Type
Headset adapter
Connector
4 pin USB Type A - male
Plug and Play, Directive 2003/10/CE
Resources
The following resources are available for the Jabra LINK 265 QD To USB Training Cable
Type: Cable
Brand: Jabra
