Jabra Link 260 USB-amplifier QD to USB
Quicklinx: 9TCDWS00 Mfr#: 260-09
Type: amplifier
25 In Stock
£64.68 ex VAT
£77.61 inc VAT
The Jabra Link 260 extends the capability of your Jabra corded QD (Quick Disconnect) headset, provides call control and enhances the audio at the same time. With the plug-and-play USB adapter, you can use your Jabra deskphone headset together with your softphone. The Digital Signal Processing (DSP) technology evens out the audio stream to ensure a clear sound on both ends of the call.
  • Call control at your fingertips
    Convenient in-line control buttons let you enjoy quick, optimised use of your softphone. At the press of a button you can answer/end calls, put calls on hold, adjust volume and mute the microphone. All of the buttons can be programmed from the computer to perform user-defined tasks such as "Call on hold", "Reject incoming call", "Redial last number" and/or "Dial voice mail" or to comply with commands in future softphones.
  • Built to withstand even the toughest work environments
    To ensure long service life, Jabra Link 260 is made of durable high-quality materials built to withstand even the toughest work environments.
  • Ideal for hot desking
    The Jabra Link 260 is the perfect solution for companies looking for greater workplace flexibility, including hot desking.
Jabra LINK 260 - headset adapter
Cable
Headset adapter
Connector
USB - male
Connector (Second End)
Quick Disconnect
In-cord volume control, answer/end button, mute switch, Digital Signal Processing (DSP) technology, acoustic shock protection, programmable buttons
BIZ 2300 Duo, 2300 MS QD Mono, 2300 QD Mono, 2400 Duo, 2400 Mono Headband
Cable Type
Headset adapter
Connector
4 pin USB Type A - male
Quick Disconnect
Plug and Play, Directive 2003/10/CE
Jabra BIZ 2300 Duo, 2300 MS QD Mono, 2300 QD Mono, 2400 Duo, 2400 Mono Headband
Type: amplifier
Brand: Jabra
