The Jabra Link 260 extends the capability of your Jabra corded QD (Quick Disconnect) headset, provides call control and enhances the audio at the same time. With the plug-and-play USB adapter, you can use your Jabra deskphone headset together with your softphone. The Digital Signal Processing (DSP) technology evens out the audio stream to ensure a clear sound on both ends of the call.
                Call control at your fingertipsConvenient in-line control buttons let you enjoy quick, optimised use of your softphone. At the press of a button you can answer/end calls, put calls on hold, adjust volume and mute the microphone. All of the buttons can be programmed from the computer to perform user-defined tasks such as "Call on hold", "Reject incoming call", "Redial last number" and/or "Dial voice mail" or to comply with commands in future softphones.
                Built to withstand even the toughest work environmentsTo ensure long service life, Jabra Link 260 is made of durable high-quality materials built to withstand even the toughest work environments.
                Ideal for hot deskingThe Jabra Link 260 is the perfect solution for companies looking for greater workplace flexibility, including hot desking.
- Jabra LINK 260 - headset adapter
- Cable
- Headset adapter
- Connector
- USB - male
- Connector (Second End)
- Quick Disconnect
- Answer/end button, in-cord volume control, mute switch, Digital Signal Processing (DSP) technology, acoustic shock protection, programmable buttons
- Designed For
- BIZ 2300 Duo, 2300 MS QD Mono, 2300 QD Mono, 2400 Duo, 2400 Mono Headband
- Cable Type
- Headset adapter
- Connector
- 4 pin USB Type A - male
- Quick Disconnect
- Plug and Play, Directive 2003/10/CE
- Designed For
- Jabra BIZ 2300 Duo, 2300 MS QD Mono, 2300 QD Mono, 2400 Duo, 2400 Mono Headband
