The Jabra Link 260 extends the capability of your Jabra corded QD (Quick Disconnect) headset, provides call control and enhances the audio at the same time. With the plug-and-play USB adapter, you can use your Jabra deskphone headset together with your softphone. The Digital Signal Processing (DSP) technology evens out the audio stream to ensure a clear sound on both ends of the call.
Call control at your fingertips
Convenient in-line control buttons let you enjoy quick, optimised use of your softphone. At the press of a button you can answer/end calls, put calls on hold, adjust volume and mute the microphone. All of the buttons can be programmed from the computer to perform user-defined tasks such as "Call on hold", "Reject incoming call", "Redial last number" and/or "Dial voice mail" or to comply with commands in future softphones. -
Built to withstand even the toughest work environments
To ensure long service life, Jabra Link 260 is made of durable high-quality materials built to withstand even the toughest work environments. -
Ideal for hot desking
The Jabra Link 260 is the perfect solution for companies looking for greater workplace flexibility, including hot desking.
- Jabra LINK 260 - headset adapter
- Cable
- Headset adapter
- Connector
- USB - male
- Connector (Second End)
- Quick Disconnect
- Answer/end button, in-cord volume control, mute switch, Digital Signal Processing (DSP) technology, acoustic shock protection, programmable buttons
- Designed For
- BIZ 2300 Duo, 2300 MS QD Mono, 2300 QD Mono, 2400 Duo, 2400 Mono Headband
- Cable Type
- Headset adapter
- Connector
- 4 pin USB Type A - male
- Quick Disconnect
- Plug and Play, Directive 2003/10/CE
- Designed For
- Jabra BIZ 2300 Duo, 2300 MS QD Mono, 2300 QD Mono, 2400 Duo, 2400 Mono Headband
