The Jabra Link 230 extends the capability of your Jabra corded QD (Quick Disconnect) headset and enhances the audio at the same time. With the plug-and-play USB adapter, you can use your Jabra deskphone headset together with your softphone. The Digital Signal Processing (DSP) technology evens out the audio stream to ensure a clear sound on both ends of the call.
Built to withstand even the toughest work environments
To ensure long service life, Jabra Link 230 is made of durable high-quality materials built to withstand even the toughest work environments.
- Jabra LINK 230 - headset adapter
- Cable
- Headset adapter
- Connector
- USB - male
- Connector (Second End)
- Quick Disconnect
- Digital Signal Processing (DSP) technology
- Cable Type
- Headset adapter
- Connector
- 4 pin USB Type A - male
- Quick Disconnect
- Plug and Play, Directive 2003/10/CE
Jabra LINK 230 QD - USB Adapter
