Jabra LINK 230 QD - USB Adapter
Quicklinx: 9TCCWS00 Mfr#: 230-09
Type: adaptor
More than 50 In Stock
£23.60 ex VAT
£28.32 inc VAT
Express delivery Order within the next 14 hours for delivery on Monday
The Jabra Link 230 extends the capability of your Jabra corded QD (Quick Disconnect) headset and enhances the audio at the same time. With the plug-and-play USB adapter, you can use your Jabra deskphone headset together with your softphone. The Digital Signal Processing (DSP) technology evens out the audio stream to ensure a clear sound on both ends of the call.
  • Built to withstand even the toughest work environments
    To ensure long service life, Jabra Link 230 is made of durable high-quality materials built to withstand even the toughest work environments.
Jabra LINK 230 - headset adapter
Cable
Headset adapter
Connector
USB - male
Connector (Second End)
Quick Disconnect
Cable Type
Headset adapter
Connector
4 pin USB Type A - male
Quick Disconnect
Plug and Play, Directive 2003/10/CE
Type: adaptor
Brand: Jabra
