Jabra LINK 230 QD - USB Adapter
Quicklinx: 9TCCWS00 Mfr#: 230-09
Type: adaptor
£37.79 ex VAT
£45.34 inc VAT
The Jabra Link 230 extends the capability of your Jabra corded QD (Quick Disconnect) headset and enhances the audio at the same time. With the plug-and-play USB adapter, you can use your Jabra deskphone headset together with your softphone. The Digital Signal Processing (DSP) technology evens out the audio stream to ensure a clear sound on both ends of the call.
  • Built to withstand even the toughest work environments
    To ensure long service life, Jabra Link 230 is made of durable high-quality materials built to withstand even the toughest work environments.
Jabra LINK 230 - headset adapter
Cable
Headset adapter
Connector
USB - male
Connector (Second End)
Quick Disconnect
Cable Type
Headset adapter
Connector
4 pin USB Type A - male
Quick Disconnect
Plug and Play, Directive 2003/10/CE
Type: adaptor
Brand: Jabra
