Jabra LINK 180 USB Adapter
Quicklinx: 7LK5WS00 Mfr#: 180-09
Recommended Use: Accessory
Connectivity: [N/A]
Earcover : [N/A]
15 in stock
£31.97 ex VAT
£38.36 inc VAT
Jabra Link 180 provides a smooth and cost-effective migration path from traditional telephony to Unified Communications. If you already have a deployment of headsets, there is no need to buy new ones. The switch enables you to answer calls from deskphones and softphone clients using the same Jabra QD (Quick Disconnect) headset.
Jabra Link 180 is compatible with any corded Jabra QD headset and all leading brands of softphones.
  • Protect your headset investment
    Jabra Link 180 is compatible with any corded Jabra QD headset and all leading brands of softphones. As a result, users can continue to leverage the benefits of a professional Jabra headset, including superior sound, noise-cancelling microphone and all-day wearing comfort.
  • One headset for your deskphone and softphone
    The Jabra Link 180 switch enables you to answer calls from deskphones and softphone using the same Jabra QD (Quick Disconnect) headset. This makes Jabra Link 180 ideal for offices and contact centres, which are in transition to Unified Communications, or use a combination of desk and softphones to maximise operational efficiency.
Jabra LINK 180 - headset switch for headset
Headset switch
Intended For
Headset
Headset switch
Intended For
Headset
Connectivity: [N/A]
Earcover : [N/A]
Brand: Jabra
Price Range Ex VAT: 0 - 50
