Jabra LINK 14201-31 Cable For NEC DT 730 Phones
Quicklinx: 84M8WS00 Mfr#: 14201-31
Recommended Use: Accessory
Connectivity: [N/A]
Earcover : [N/A]
£41.09 ex VAT
£49.30 inc VAT
Enjoy wireless freedom and get remote call control on your wireless headset from a wide range of NEC deskphones using an Electronic Hook Switch (EHS) cord. Answer or end calls, mute the microphone and adjust volume when you are away from the desk.
  • 150 Metres Wireless Freedom
    The Jabra Link 14201 series puts the freedom and convenience of wireless communication in everyone's reach. You can now walk and talk up to 150 metres away from your deskphone. Answer calls, multitask and move around on your terms.
  • Easy to deploy
    The Jabra Link 14201 series is optimised for use with all leading deskphone systems that provide EHS functionality and enables plug-and-play remote call control functionality with your cordless headset.
  • Remote Call Control
    Answer and end calls, adjust the volume and mute your call on the Jabra wireless headset with seamless integration between your deskphone and headset. The remote call control gives you the power to multitask and be productive.
Jabra LINK - electronic hook switch adapter
Electronic hook switch adapter
GO 6470; PRO 920, 930, 930 MS, 930 UC, 9470, 9470 NCSA; NEC DT730 12D, DT730 24D, DT730 32D
Jabra GO 6470 , Jabra PRO 920, 930, 930 MS, 930 UC, 9470, 9470 NCSA , NEC DT730 12D, DT730 24D, DT730 32D
Connectivity: [N/A]
Earcover : [N/A]
Brand: Jabra
