Jabra Link 14201-17 - headset adapter - 92.5 cm
Quicklinx: JD2KWS00 Mfr#: 14201-17
31 In Stock
£41.05 ex VAT
£49.26 inc VAT
Enjoy wireless freedom and get remote call control on your wireless headset from a wide range of Polycom SoundPoint IP phones using an Electronic Hook Switch (EHS) cord. Answer or end calls, mute the microphone and adjust volume when you are away from the desk.
Cable
Headset adapter
Cable Length
92.5 cm
Answer/end button, mute switch, volume buttons, Electronic Hook Switch Control (EHS)
1-year warranty
Jabra GN9120 Duo, GN9120 Midi, GN9350; Poly - Polycom SoundPoint IP 320, IP 330, IP 430, IP 550, IP 560, IP 650
Cable Type
Headset adapter
Cable Length
92.5 cm
Plug and Play, C-Tick, NOM, IC, FCC
Limited warranty - 1 year
Jabra GN9120 Duo, GN9120 Midi, GN9350 , Poly - Polycom SoundPoint IP 320, IP 330, IP 430, IP 550, IP 560, IP 650
Brand: Jabra
