Jabra Jabra GN1200 Smartcord -Straight
Quicklinx: F1CZWS00 Mfr#: 88001-99
Recommended Use: Headset
Connectivity: [N/A]
Earcover : [N/A]
£18.48 ex VAT
£22.17 inc VAT
The Jabra GN1200 cord is the solution to the common problem of not being able to connect your headset and telephone. Even though most things have been standardised, the cord connecting the deskphone with the handset or headset is anything but standard as each telephone manufacturer has its own wiring code. Now, with the Jabra GN1200 universal audio processor cord, one cord will work with virtually any phone, providing greater convenience. The Jabra GN1200 features eight microphone volume settings to ensure that the volume of all outgoing calls is at the same user-defined comfortable level.
  • Easy to deploy
    Jabra GN1200 Series audio processor cords make it possible to connect virtually any deskphone with Jabra's Quick Disconnect corded headsets. Even though the headset and deskphone may be plug compatible, the wiring is determined by the individual telephone manufacturer. The Jabra GN1200 series cords feature eight separate wiring schemes – including three with built-in microphone amplification. Just connect the cord and the headset through the Quick Disconnect plug and flick the slider from one position to the next until a dial tone is heard. It's as simple as that!
  • Microphone amplification
    The Jabra GN1200 series cords feature eight microphone volume settings to ensure that the volume of all outgoing calls is at the same user-defined comfortable level.
Jabra Smart Cord - headset cable
Cable
Headset cable
Avaya 11XX, 12XX, IP Phone 1140; Cisco IP Phone 78XX; Small Business SPA 301; Unified IP Phone 69XX, 79XX, 89XX, 99XX; BIZ 2300, 2400; Mitel 74XX; Dialog 42XX, 44XX, 5446; Nortel IP Phone 11XX; Siemens OpenStage 15, 20; Snom 370, 71X, 720, 760, 821, 870; Unify OpenStage 15, 20; optiPoint 410
Cable Type
Headset cable
Avaya 1120E, 1140E IP Deskphone, 1150E IP Deskphone, 1165E IP Deskphone, 1210 IP Deskphone, 1220 IP Deskphone, 1230 IP Deskphone, IP Phone 1140E , Avaya CallMaster V, VI Voice Terminal , Cisco IP Phone 7821, 7841, 7861, 7940G, 7960G , Cisco Small Business SPA 301 , Cisco Unified IP Phone 6901 Slimline, 6901 Standard, 6911 Slimline, 6911 Standard, 6921, 6921 Slimline, 6921 Standard, 6941, 6941 Slimline, 6941 Standard, 6945 Slimline, 6945 Standard, 6961 Slimline, 6961 Standard, 7931G, 7940G, 7942G, 7945G, 7960G, 7962G, 7965G, 7971G, 7975G, 8941 Slimline, 8941 Standard, 8945 Slimline, 8945 Standard, 8961 Slimline, 8961 Standard, 9951 Slimline, 9951 Standard, 9971 Slimline, 9971 Standard , Ericsson Dialog 3212, 3213, 4222 Office, 4223 Professional, 4224 Operator, 4425 IP Vision , Jabra BIZ 2300 QD Duo, 2300 QD Mono, 2400 Duo, 2400 Mono, 3-in-1 , Mitel 7433ip, 7434ip , Mitel Dialog 4222 OFFICE, 4223 Professional, 4224 Operator, 4420 IP Basic, 4422 IP Office, 4425 IP Vision, 5446 IP Premium , Nortel IP Phone 1110, IP Phone 1140E, IP Phone 1150E, IP Phone 1165E, IP Phone 1210, IP Phone 1220, IP Phone 1230 , Siemens OpenStage 15, 20 , Snom 370, 710, 715, 720, 760, 821, 870 , Unify OpenStage 15, 20 , Unify optiPoint 410
Connectivity: [N/A]
Earcover : [N/A]
Brand: Jabra
