Enjoy wireless freedom and get remote call control on your wireless headset from a wide range of Cisco Unified IP phones using an Electronic Hook Switch (EHS) cord. Answer or end calls, mute the microphone and adjust volume when you are away from the desk.
150 Metres Wireless Freedom
The Jabra Link 14201 series puts the freedom and convenience of wireless communication in everyone's reach. You can now walk and talk up to 150 metres away from your deskphone. Answer calls, multitask and move around on your terms. -
Easy to deploy
The Jabra Link 14201 series is optimised for use with all leading deskphone systems that provide EHS functionality and enables plug-and-play remote call control functionality with your cordless headset. -
Remote Call Control
Answer and end calls, adjust the volume and mute your call on the Jabra wireless headset with seamless integration between your deskphone and headset. The remote call control gives you the power to multitask and be productive.
- Jabra Link 14201-16 - headset adapter - 92.5 cm
- Cable
- Headset adapter
- Length
- 92.5 cm
- Answer/end button, mute switch, volume buttons, Electronic Hook Switch Control (EHS)
- 1-year warranty
- Designed For
- Cisco Unified IP Phone 7942G, 7945G, 7962G, 7965G, 7975G
- Cable Type
- Headset adapter
- Length
- 92.5 cm
- Plug and Play, C-Tick, NOM, IC, FCC
- Limited warranty - 1 year
- Designed For
