Jabra Halo Fusion
Jabra Halo Fusion
Quicklinx: CCB2WS00 Mfr#: 100-97800000-60
Your calls. Your music. One headset. For work. For play. One headset.
Switch seamlessly between calls and music.
  • Great calls and sound
    With 6.5 hours of music and talk time, the in-ear headphones isolate surrounding noise so you can hear all the details of your call and listen to every beat of your music.
  • Great calls the easy way
    Jabra Halo Fusion, the Bluetooth headphones that seamlessly switch between calls and music. With simple one-touch control and a comfortable wearing style, Halo Fusion provides a lightweight and convenient solution for those who like to easily access calls and music when on the go.
  • Light and convenient
    Relish in the convenience of a neckband that gives you easy access to your headphones throughout the day. The easy-to-reach headphones allow you to quickly insert and remove each earbud while your phone stays in your pocket. At just 21 g (0.7 oz), you won't feel the need to take your headphones off.
  • Switch between calls and music with one touch
    Jabra Halo Fusion allows you to control your calls and music directly from your headphones with one-touch controls, without ever needing to reach for your phone in your pocket. Switching between calls and music has never been so seamlessly easy – switch with one touch only.
Jabra HALO FUSION - headset
Headset - Bluetooth - wireless
Recommended Use
Portable electronics
Additional Functions
USB charging port
Headphones Form Factor
In-ear
Wireless
Wireless Technology
Bluetooth
Headphones Technology
Dynamic
Bluetooth Version
Bluetooth 4.0
Sound Output Mode
Stereo
Audio Specifications
Frequency Response 20 - 20000 Hz - Sensitivity 98 dB
Impedance
16 Ohm
Max Input Power
10 mW
Noise Isolating
Controls
Volume control, play/pause button, answer/end, next/previous track
1-year warranty
USB charging port
13.605 cm
1.1 cm
15.56 cm
21 g
Body Material
Silicone, TPE, PC/ABS
Recommended Use
Max Operating Distance
10 m
Audio Output
In-ear
Dynamic
Wireless
Wireless Technology
Bluetooth
Bluetooth Version
Bluetooth 4.0
Bluetooth Profiles
Hands-Free Profile (HFP), Headset Profile (HSP), Advanced Audio Distribution Profile (A2DP), Audio/Video Remote Control Profile (AVRCP)
Sound Output Mode
Stereo
Noise Isolating
Frequency Response
20 - 20000 Hz
Max Input Power
10 mW
Sensitivity
98 dB
Impedance
16 Ohm
Diaphragm
9 mm
Microphone
Sensitivity
-42 dB
Frequency Response
100 - 8000 Hz
Audio Input Details
Omni-directional
Remote Control
Controls
Wireless Link
Transmission Range
10 m
2 pairs of ear tips (small, large)
Cable Details
USB charge cable - 30 cm
Headset battery rechargeable
Run Time (Up To)
6.5 hour(s)
Standby Time
456 hours
Recharge Time
2 hour(s)
Limited warranty - 1 year
