The GN 2100 Telecoil is the state-of-the-art, professional headset for hearing aid wearers. It is equipped with a hearing aid-compatible telecoil, suitable for all standard telecoil-equipped hearing aids and fitted to the plain side of the earpiece. The telecoil cancels out surrounding background noise and heightens the sound quality from the telephone for clearer, crisper phone conversations.
- Telecoil-equipped headset for those with special hearing needs
- Filters out unwanted background noise with noise canceling microphone
- Ultra lightweight for all-day wearing comfort
- Only one side of the headset works for sound
This headset does NOT include a bottom cord
For use with hearing aids only
Multiple wearing options
Wear it exactly the way you want. Choose from four different wearing styles: headband, behind the neck, ear hook or ear loop. Comes with a selection of ear plates and ear cushions. -
Noise-cancelling microphones
Make yourself heard. Advanced noise-cancelling microphones filter out ambient noise and make sure only your voice comes through. -
Stylish & comfortable design
GN2100 looks great and is built for comfort. Its lightweight frame and adjustable boom-arm guarantee the perfect fit for all-day wear. -
PeakStop?
PeakStop? instantly removes any harmful loud sounds before they even reach your ears. This keeps the sound level in the safe range and protects your hearing. -
Talk in Comfort
Find the perfect fit with a range of light, ergonomically designed frames, soft ear cushions, adjustable headbands and microphone boom. Your headset will be comfortable all day long.
- Jabra GN 2100 Telecoil - headset
- Product Type
- Headset - wired
- Recommended Use
- Phone
- Headphones Form Factor
- On-ear
- Connectivity Technology
- Wired
- Headphones Technology
- Dynamic
- Microphone
- Boom
- Microphone Operation Mode
- Mono
- 2-year warranty
- Product Type
- Headset - wired
- Recommended Use
- Phone
Audio Output
- On-ear
- Dynamic
- Wired
Microphone
- Boom
- Mono
- Limited warranty - 2 years
Jabra LINK 860 Amplifier | In Stock | £79.76 |
