The Jabra GN2000 Series lets you hear every detail, the first time. For PC-based IP telephony, the Jabra GN2000 IP and Jabra GN2000 USB supports the full IP network bandwidth for applications such as speech recognition, voice-over-IP calling and computer-based training. For traditionel telephony, the Jabra GN2000 Series is the ideal headset for busy and noisy environments, utilising the full frequency of the telephone network to ensure exceptional sound quality on every call.
From its sturdy rubber-plastic composite to reinforced strain relief and impact resistant headbands, every detail of the Jabra GN2000 Series has been designed with durability in mind - making it perfect for even the most demanding contact centres.
- Robust design for day-after-day durability
- Optimized for contact center use
- Noise canceling microphone for the noisy environment
- Wideband sound
Talk In Comfort
Be kind to your ears Ensure total comfort with a wide range of styles that match your individual needs and personal fit requirements. Our light, ergonomically designed frames along with soft ear cushions, adjustable headbands and microphone boom will guarantee that your headset will be comfortable all day long. -
Noise Cancelling Microphone
Reduces unwanted background noise Noise cancelling microphones reduce unwanted background noise and are ideal in crowded and noisy, open office environments. -
PeakStop
Safe sound and superior hearing protection PeakStop technology immediately removes potentially harmful loud sounds or tones before they reach your ears and keeps the sound level within the safe range to protect your hearing. -
HD Voice - Wideband Audio
High quality audio for crystal clear conversations Enjoy high-definition sound with HD Voice and get crystal clear, intelligible communication. You get lifelike, vibrant conversations where you can focus on the content and don't have to struggle to understand what the person on the other end of the line is saying.
- Jabra GN2000 MONO NC WB - headset
- Product Type
- Headset - wired
- Recommended Use
- Conference
- Headphones Form Factor
- On-ear monaural
- Connectivity Technology
- Wired
- Sound Output Mode
- Mono
- Audio Specifications
- Frequency Response 150 - 6800 Hz
- Impedance
- 200 Ohm
- Microphone
- Boom
- Microphone Operation Mode
- Mono
- 2-year warranty
- Product Type
- Headset - wired
- 52 g
- Recommended Use
- Conference
Audio Output
- On-ear monaural
- Wired
- Sound Output Mode
- Mono
- 150 - 6800 Hz
- Impedance
- 200 Ohm
Microphone
- Boom
- Mono
- Wired
- Sensitivity
- -34 dB
- Limited warranty - 2 years
