Jabra GN1221 Sound Limiter QD To RJ9
Quicklinx: 7X6SWS00 Mfr#: 88007-99
Type: Misc
More than 50 In Stock
£22.11 ex VAT
£26.53 inc VAT
The Jabra GN1221 cord is the solution to the common problem of not being able to connect your headset and telephone. Even though most things have been standardised, the cord connecting the phone with the handset or headset is anything but standard as each telephone manufacturer has its own wiring code. Now, with the Jabra GN1221 QD to RJ9 universal audio processor cord, one cord will work with virtually any phone, providing greater convenience.
Jabra GN1221 is compliant with the EU Noise-at-Work legislation (Directive 2003/10/EC). The Jabra GN1221 features eight microphone volume settings to ensure that the volume of all outgoing calls is at the same user-defined comfortable level.
  • Easy to deploy
    Jabra GN1200 Series audio processor cords make it possible to connect virtually any deskphone with Jabra's Quick Disconnect corded headsets. Even though the headset and deskphone may be plug compatible, the wiring is determined by the individual telephone manufacturer. The Jabra GN1200 series cords feature eight separate wiring schemes – including three with built-in microphone amplification. Just connect the cord and the headset through the Quick Disconnect plug and flick the slider from one position to the next until a dial tone is heard. It's as simple as that!
  • Microphone amplification
    The Jabra GN1200 series cords feature eight microphone volume settings to ensure that the volume of all outgoing calls is at the same user-defined comfortable level.
Jabra GN1221 Sound Limiter - headset cable - 80 cm
Cable
Headset cable
Length
80 cm
Connector
RJ-9 - male
Connector (Second End)
Quick Disconnect
Cable Type
Headset cable
Length
80 cm
Connector
RJ-9 - male
Quick Disconnect
EN 2003/10/EC
Type: Misc
Brand: Jabra
Stock Status: Clearance
