Jabra GN1216 Straight Headset Cable
Quicklinx: 750SWS00 Mfr#: 88001-03
£19.19 ex VAT
£23.02 inc VAT
The Jabra GN1216 cord is the solution for Avaya one-X Deskphone 9600 and 1600 series where microphone volume controls are needed. The Jabra GN1216 cord has been designed to offer unique connectivity and supports wideband sound. The Jabra GN1216 features eight microphone volume settings to ensure that the volume of all outgoing calls is at the same user-defined comfortable level.
  • Easy to deploy
    Jabra GN1200 Series audio processor cords make it possible to connect virtually any deskphone with Jabra's Quick Disconnect corded headsets. Even though the headset and deskphone may be plug compatible, the wiring is determined by the individual telephone manufacturer. The Jabra GN1200 series cords feature eight separate wiring schemes – including three with built-in microphone amplification. Just connect the cord and the headset through the Quick Disconnect plug and flick the slider from one position to the next until a dial tone is heard. It's as simple as that!
  • Microphone amplification
    The Jabra GN1200 series cords feature eight microphone volume settings to ensure that the volume of all outgoing calls is at the same user-defined comfortable level.
Jabra GN1216 - headset cable - 80 cm
Cable
Headset cable
Length
80 cm
Connector
Quick Disconnect - plug
Connector (Second End)
RJ-9 - male
Avaya one-X Deskphone Edition 9610, 9620, 9620C, 9620L, 9630, 9630G, 9640, 9640G, 9650, 9650C, 9670G; one-X Deskphone Value Edition 1603, 1603-I, 1603SW, 1603SW-I, 1608, 1608-I, 1616, 1616-I, 1716; Jabra GN 2000, GN 2100, GN 2100 3-in-1, GN2000; BIZ 2400, 2400 3in1, GN2000
Cable Type
Headset cable
Length
80 cm
Connector
RJ-9 - male
Avaya one-X Deskphone Edition 9610 IP Telephone, 9620 IP Telephone, 9620C IP Telephone, 9620L IP Telephone, 9630 IP Telephone, 9630G IP Telephone, 9640 IP Telephone, 9640G IP Telephone, 9640G IP Telephone w/o faceplate, 9650 IP Telephone, 9650C IP Telephone, 9670G , Avaya one-X Deskphone Value Edition 1603, 1603-I, 1603SW, 1603SW-I, 1608, 1608-I, 1616, 1616-I, 1716 , Jabra GN 2000 Duo Flex. NC, GN 2000 Duo. Omni, GN 2000 Flex Mono, GN 2000 IP, GN 2000 Mono, GN 2000 Mono. Omni, GN 2000 NC Mono, GN 2000 NC Mono IP OC, GN 2000 Sound Tube Mono, GN 2000 Standard Mono Flex, GN 2100, GN 2100 3-in-1, GN 2100 DUO, GN 2100 Fixed-Boom, GN 2100 Fixed-boom 3-in-1, GN 2100 Fixed-Boom Duo, GN 2100 Flex-Boom, GN 2100 Flex-Boom 3-in-1, GN 2100 Flex-Boom Duo, GN 2100 Micro Boom LS, GN 2100 Micro-Boom, GN 2100 Micro-Boom 3-in-1, GN 2100 Micro-Boom Duo, GN 2100 Telecoil, GN 2100 VoIP 3-i-1 Flex. NC, GN 2100 VoIP Duo Flex. NC, GN2000, GN2000 Duo, GN2000 Duo, Narrow Band, GN2000 Duo, SoundTube, GN2000 Duo, SoundTube, Narrow Band, GN2000 IP Duo NC, GN2000 IP Mono Flex. NC, GN2000 IP OC Mono, GN2000 Mono Flex. NC, GN2000 MONO NC WB, GN2000 MONO SOUNDTUBE WB, GN2000 Mono, SoundTube, Narrow Band, GN2000 NC Duo, GN2000 NC DUO WB, GN2000 Sound Tube Duo , Jabra BIZ 2400 3in1 WB Balance, 2400 Duo, 2400 Duo IP, 2400 Duo WB Balance, 2400 Mono Headband, 2400 Mono IP 3-in-1, 2400 Mono, 3-in-1, GN2000 Duo, SoundTube, Narrow Band, GN2000 MONO NC WB
Brand: Jabra
