Jabra GN1216 - headset cable - 2 m
Quicklinx: HYM4WS00 Mfr#: 88001-04
More than 50 In Stock
£30.13 ex VAT
£36.15 inc VAT
Jabra's audio processors work with your company's deskphones to ensure excellent call quality and provide a safe audio level for your employees. Designed for contact centres and phone-intensive offices.
  • Efficient connectivity
    The Jabra GN1216 features a Quick Disconnect to RJ-9 connection, ensuring seamless integration with office phone systems. This efficient connectivity option allows for quick and easy setup, making it an ideal solution for busy professionals.
  • Durable design
    With its coiled cable and robust connectors, the Jabra GN1216 is built to withstand the rigors of daily use. The male connectors on both ends are designed for a secure fit, reducing the risk of disconnection during important calls.
Cable
Headset cable
Cable Length
2 m
Connector
RJ-9 - male
Connector (Second End)
Quick Disconnect - male
Coiled
Avaya one-X Deskphone Edition 9610, 9620, 9620C, 9620L, 9630, 9630G, 9640, 9640G, 9650, 9650C, 9670G; one-X Deskphone Value Edition 1603, 1603-I, 1603SW, 1603SW-I, 1608, 1608-I, 1616, 1616-I, 1716; Jabra GN 2000, GN 2100, GN 2100 3-in-1, GN1900, GN2000; BIZ 2400, 2400 3in1, GN2000
Cable Type
Headset cable
Cable Length
2 m
Coiled
Connector
RJ-9 - male
Avaya one-X Deskphone Edition 9610 IP Telephone, 9620 IP Telephone, 9620C IP Telephone, 9620L IP Telephone, 9630 IP Telephone, 9630G IP Telephone, 9640 IP Telephone, 9640G IP Telephone, 9640G IP Telephone w/o faceplate, 9650 IP Telephone, 9650C IP Telephone, 9670G , Avaya one-X Deskphone Value Edition 1603, 1603-I, 1603SW, 1603SW-I, 1608, 1608-I, 1616, 1616-I, 1716 , Jabra GN 2000 Duo Flex. NC, GN 2000 Duo. Omni, GN 2000 Flex Mono, GN 2000 IP, GN 2000 Mono, GN 2000 Mono. Omni, GN 2000 NC Mono, GN 2000 NC Mono IP OC, GN 2000 Sound Tube Mono, GN 2000 Standard Mono Flex, GN 2100, GN 2100 3-in-1, GN 2100 DUO, GN 2100 Fixed-Boom, GN 2100 Fixed-boom 3-in-1, GN 2100 Fixed-Boom Duo, GN 2100 Flex-Boom, GN 2100 Flex-Boom 3-in-1, GN 2100 Flex-Boom Duo, GN 2100 Micro Boom LS, GN 2100 Micro-Boom, GN 2100 Micro-Boom 3-in-1, GN 2100 Micro-Boom Duo, GN 2100 Telecoil, GN 2100 VoIP 3-i-1 Flex. NC, GN 2100 VoIP Duo Flex. NC, GN1900 DUO NC, GN1900 Mono NC, GN2000, GN2000 Duo, GN2000 Duo, Narrow Band, GN2000 Duo, SoundTube, GN2000 Duo, SoundTube, Narrow Band, GN2000 IP Duo NC, GN2000 IP Mono Flex. NC, GN2000 IP OC Mono, GN2000 Mono Flex. NC, GN2000 MONO NC WB, GN2000 MONO SOUNDTUBE WB, GN2000 Mono, SoundTube, Narrow Band, GN2000 NC Duo, GN2000 NC DUO WB, GN2000 Sound Tube Duo , Jabra BIZ 2400 3in1 WB Balance, 2400 Duo, 2400 Duo IP, 2400 Mono Headband, 2400 Mono IP 3-in-1, 2400 Mono, 3-in-1, GN2000 Duo, SoundTube, Narrow Band, GN2000 MONO NC WB
Brand: Jabra
