Jabra GN1210 Carbon - RJ9 Plug
Quicklinx: 7T4MWS00 Mfr#: 88001-96
£38.91 ex VAT
£46.69 inc VAT
The Jabra GN1210 straight RJ-9 cord is the solution to a common problem of not being able to connect headset and carbon-based telephone. Even though most things have been standardized, the cord connecting the carbon-based phone with the handset or headset is anything but standard as each telephone manufacturer has its own wiring code. Now, with the universal "smart" cord, GN 1210, the cord will work with virtually any carbon-based phone system providing greater convenience. Available in both straight and coiled versions, the GN 1210 fits virtually all carbon-based telephones featuring a standard RJ 9 modular connector.
  • Simple 8-position slide adjustment
    No need for a user manual; simply slide until receiving end can hear you clearly.
  • Standard GN Quick Disconnect plug to headset
    It is guaranteed to work with the most popular headsets equipped with Quick Disconnect.
Jabra GN1210 - headset cable - 80 cm
Cable
Headset cable
Length
80 cm
Connector
Quick Disconnect - male
Connector (Second End)
RJ-9 - male
Cable Type
Headset cable
Length
80 cm
Connector
RJ-9 - male
Brand: Jabra
