Jabra GN1200  Smartcord (Curly) - for Desk Phone Connectivity
Quicklinx: 5D6YWS00 Mfr#: 88011-99
Length: 2m
Hurry, only 1 left in stock!
£20.89 ex VAT
£25.06 inc VAT
Express delivery Order within the next 20 hours for delivery on Wednesday
The Jabra GN1200 coiled cord is the solution to a common problem of not being able to connect headset and telephone. Even though most things have been standardized, the cord connecting the phone with the handset or headset is anything but standard as each telephone manufacturer has its own wiring code. Now, with the universal "smart" cord, GN 1200, the cord will work with virtually any phone providing greater convenience.
  • Easy to deploy
    Jabra GN1200 Series audio processor cords make it possible to connect virtually any deskphone with Jabra's Quick Disconnect corded headsets. Even though the headset and deskphone may be plug compatible, the wiring is determined by the individual telephone manufacturer. The Jabra GN1200 series cords feature eight separate wiring schemes – including three with built-in microphone amplification. Just connect the cord and the headset through the Quick Disconnect plug and flick the slider from one position to the next until a dial tone is heard. It's as simple as that!
  • Microphone amplification
    The Jabra GN1200 series cords feature eight microphone volume settings to ensure that the volume of all outgoing calls is at the same user-defined comfortable level.
Jabra GN1200 CC - headset cable - 2 m
Cable
Headset cable
Length
2 m
Connector
Quick Disconnect - plug
Connector (Second End)
RJ-9 - male
Coiled
Jabra GN 2100, GN 2100 Fixed-Boom, GN 2100 Fixed-boom 3-in-1, GN 2100 Fixed-Boom Duo, GN 2100 Flex-Boom, GN 2100 Flex-Boom 3-in-1, GN 2100 Flex-Boom Duo, GN 2100 Micro-Boom, GN 2100 Micro-Boom 3-in-1, GN 2100 Micro-Boom Duo, GN 2100 Telecoil, GN 2200 Duo, GN 2200 Flex, GN 2200 Mono, GN 2250
Cable Type
Headset cable
Length
2 m
Coiled
Connector
RJ-9 - male
Resources
The following resources are available for the Jabra GN1200 Smartcord (Curly) - for Desk Phone Connectivity
Length: 2m
Brand: Jabra
