Your basket is empty
Jabra GN1000 Remote Handset Lifter
Quicklinx: 6JKNWS00 Mfr#: 1000-04
£37.77 ex VAT
£45.32 inc VAT
The GN 1000 Remote Handset Lifter, designed exclusively for use with GN Netcom wireless headset systems, lifts the handset from your telephone so you can answer and end calls when away from your desk.
The GN 1000 Remote Handset Lifter is the perfect accessory for your GN Netcom wireless headset system. With the GN 1000, you can answer and end calls, from wherever your wireless headset takes you. It's easy to install, and its one-button operation means ease of use.
The GN 1000 senses the magnetic field the speaker generates when your phone rings, which mean you'll never miss a call or be signaled when there isn't a call. Its solid mechanical lifting components won't let you down either.
**This handset lifter does not work with Nortel Meridan M2250, 1120, 1140 or 1150**
Jabra GN 1000 Remote Handset Lifter - handset lifter
Handset lifter
Intended for
Phone
Handset lifter
Intended for
Phone
Brand: Jabra
Price Range Ex VAT: 0 - 50
