Jabra GN1000 Handset Lifter - Wireless
Quicklinx: 7SCPWS00 Mfr#: 1000-04-01
£37.77 ex VAT
£45.32 inc VAT
Enjoy wireless freedom and get remote call control on your wireless headset from virtually any deskphone. Jabra GN1000 automatically lifts your handset and returns it to the cradle. This enables you to answer or end calls, mute the microphone and adjust volume when you are away from your desk.
Jabra GN1000 is designed for deskphones that do not provide EHS functionality.
  • Completes your wireless headset solution
    With its discreet design, Jabra GN1000 fits on your telephone and enables remote call control with virtually any deskphone system. Jabra GN1000 automatically takes your handset off the hook and lets you answer calls with the touch of a button from your cordless headset.
  • 150 metres Wireless Freedom
    The Jabra GN1000 puts the freedom and convenience of wireless communication within everyone's reach. You can now walk and talk up to 150 metres away from your deskphone. Answer calls, multitask and move around on your terms.
  • Remote Call Control
    Answer and end calls, adjust the volume and mute your call on the Jabra wireless headset with seamless integration between your deskphone and headset. The remote call control gives you the power to multitask and be productive.
Jabra GN 1000 Remote Handset Lifter - handset lifter
Handset lifter
Intended For
Phone
Handset lifter
Intended For
Phone
Brand: Jabra
Price Range Ex VAT: 0 - 50
