Evolve3 85 is a complete transformation of what a professional headset can be. Built for a world where meetings happen anywhere, distractions are constant, and speed matters, it turns the everyday chaos of modern work into unstoppable flow. Jabra ClearVoice™ uses AI-powered deep learning technology, trained with 60 million sentences, to isolate your speech from background noise like never before. Jabra Advanced ANC™ dynamically adapts to your fit and surroundings, blocking distractions out and locking focus in for both music and calls. Evolve3 85 is AI-ready and built to integrate smoothly with your Gen AI assistant of choice. And it picks up more than 9 out of 10 words accurately for AI, so your prompts land first time—no repeats, no typing, just instant results. There’s no trade-off between looking good and sounding good. Evolve3 85 has a sleek design and professional performance, built to last from durable, replaceable parts. Secure. Sustainable. Ready for anything. This isn’t an upgrade. It’s a reset. Become unstoppable with Evolve3 85.
- Jabra Evolve3 85 UC - headset - 3.5 mm jack, USB-A via Bluetooth adapter - with wireless charging pad
- Product Type
- Headset - Bluetooth - wireless, wired - 3.5 mm jack, USB-A via Bluetooth adapter
- Compatibility
- Linux, Mac, Windows
- Recommended Use
- Portable electronics, computer - communication
- Black
- Headphones Form Factor
- Full size binaural
- Foldable
- Connectivity Technology
- Wireless, wired
- Wireless Technology
- Bluetooth
- Bluetooth Version
- Bluetooth 5.3 LE
- Sound Output Mode
- Stereo
- Audio Specifications
- Frequency Response 20 - 20000 Hz - Sensitivity 108.5 dB
- Impedance
- 35 Ohm
- Max Input Power
- 20 mW
- Active Noise Canceling
- Noise Isolating
- Microphone Operation Mode
- Digital MEMS
- Microphones Included
- 6
- Controls
- Mute, Microsoft Teams button, call
- Intelligent Assistant
- Siri, Google Assistant, Alexa
- Environmental Standards
- TCO Certified, generation 10, for headsets
- Software Certification
- UC certified
- 2-year warranty
- Bundled with
- Wireless charging pad
- Product Type
- Compatibility
- 19.4 cm
- 8.3 cm
- 15 cm
- 220 g
- Black
- Body Material
- Metal, PC/ABS, recycled aluminium, recycled ABS
- Headband Material
- Fabric
- Earpad Material
- Foam
- Recommended Use
- Busy light LED indicator, over the air updates, ClearVoice microphone technology, Battery status indicator, replaceable battery, sleep mode, on-head detection, Auracast, on/off switch, up to 8 devices pairing, wind noise reduction (WNR)
- Protection
- Encryption protection
- Max Operating Distance
- 30 m
- Bundled with
Audio Output
- Foldable
- Wireless, wired
- Bluetooth
- Bluetooth Audio Codec
- SBC, AAC, LC3
- Bluetooth Version
- Bluetooth 5.3 LE
- Bluetooth Profiles
- Hands-Free Profile (HFP), Headset Profile (HSP), Serial Port Profile (SPP), Advanced Audio Distribution Profile (A2DP), Audio/Video Remote Control Profile (AVRCP), Telephony and Media Audio Profile (TMAP), Public Broadcast Profile (PBP)
- Sound Output Mode
- Stereo
- Noise Isolating
- Active Noise Cancelling Technology
- Advanced ANC
- 20 - 20000 Hz
- Max Input Power
- 20 mW
- Sensitivity
- 108.5 dB
- Impedance
- 35 Ohm
- Diaphragm
- 32 mm
- Simultaneously Connectable Devices Qty
- 2
- Audio prompts, MultiPoint Technology, Jabra Direct, Google Fast Pair, Auto Pause, Jabra Xpress, Microsoft Swift Pair, HearThrough, digital signal processing, super wideband (SWB), sidetone detection, Auto resume, auto connect
Microphone
- Form Factor
- Headset microphone
- Digital MEMS
- 6
- Sensitivity
- -36 dBFS/Pa
- 10 - 20000 Hz
- Noise Cancelling Technology
- Clear Voice Technology
Remote Control
- Controls
- Connector Type
- USB (USB Type-C) ¦ Analogue input (mini-phone 3.5mm)
Internet of Things (IoT)
- Internet of Things (IoT) Compatible
- Communications Technology
- Bluetooth 5.3 LE
- Included Accessories
- Carrying case, leaflet, wireless charging pad, 3.5 mm audio cable, USB-C to USB-C cable, Jabra Link 390a Bluetooth adapter
- Cable Details
- USB-C to USB-C cable - 1.2 m ¦ Mini-phone 3.5 mm to mini-phone 3.5 mm cable
- UC certified
- AES, MFI, G616
Sustainability Information
- TCO Certified
- Battery
- Headset battery rechargeable - Lithium Ion - - wireless charging
- Capacity
- 925 mAh
- Run Time Details
- Continuous talk (ANC OFF): up to 25 hours ¦ Continuous talk (ANC ON): up to 21 hours ¦ Continuous playback (ANC ON): up to 55 hour(s) ¦ Continuous playback (with 10 min charge): up to 10 hours ¦ Continuous playback (ANC OFF): up to 120 hour(s)
- Recharge Time
- 180 min
- Limited warranty - 2 years
- Shipping Width
- 18.6 cm
- Shipping Depth
- 22 cm
- Shipping Height
- 6.2 cm
- -10 °C
- 45 °C
- Min Storage Temperature
- -10 °C
- Max Storage Temperature
- 55 °C
