Jabra Evolve3 85 MS, Link 390 USB-C, Black, with Wireless Charging Pad
Quicklinx: JF74WS00 Mfr#: 38599-999-889
Recommended Use: Computer, Portable electronics
Connectivity: Wired, Wireless
17 In Stock
£353.88 ex VAT
£424.65 inc VAT
Evolve3 85 is a complete transformation of what a professional headset can be. Built for a world where meetings happen anywhere, distractions are constant, and speed matters, it turns the everyday chaos of modern work into unstoppable flow. Jabra ClearVoice™ uses AI-powered deep learning technology, trained with 60 million sentences, to isolate your speech from background noise like never before. Jabra Advanced ANC™ dynamically adapts to your fit and surroundings, blocking distractions out and locking focus in for both music and calls. Evolve3 85 is AI-ready and built to integrate smoothly with your Gen AI assistant of choice. And it picks up more than 9 out of 10 words accurately for AI, so your prompts land first time—no repeats, no typing, just instant results. There’s no trade-off between looking good and sounding good. Evolve3 85 has a sleek design and professional performance, built to last from durable, replaceable parts. Secure. Sustainable. Ready for anything. This isn’t an upgrade. It’s a reset. Become unstoppable with Evolve3 85.
Jabra Evolve3 85 MS - headset - 3.5 mm jack, USB-C via Bluetooth adapter - Microsoft Teams Certified - with wireless charging pad
Headset - Bluetooth - wireless, wired - 3.5 mm jack, USB-C via Bluetooth adapter
Compatibility
Linux, Mac, Windows
Recommended Use
Portable electronics, computer - communication
Headphones Form Factor
Full size binaural
Foldable
Wireless, wired
Wireless Technology
Bluetooth
Bluetooth Version
Bluetooth 5.3 LE
Sound Output Mode
Stereo
Audio Specifications
Frequency Response 20 - 20000 Hz - Sensitivity 108.5 dB
Impedance
35 Ohm
Max Input Power
20 mW
Active Noise Canceling
Noise Isolating
Microphone Operation Mode
Digital MEMS
Microphones Included
6
Controls
Mute, Microsoft Teams button, call
Intelligent Assistant
Siri, Google Assistant, Alexa
Environmental Standards
TCO Certified, generation 10, for headsets
Software Certification
Certified for Microsoft Teams
Bundled with
Wireless charging pad
Compatibility
Linux, Mac, Windows
19.4 cm
8.3 cm
15 cm
220 g
Body Material
Metal, PC/ABS, recycled aluminium, recycled ABS
Headband Material
Fabric
Earpad Material
Foam
Recommended Use
Busy light LED indicator, over the air updates, ClearVoice microphone technology, Battery status indicator, replaceable battery, sleep mode, on-head detection, Auracast, on/off switch, up to 8 devices pairing, wind noise reduction (WNR)
Protection
Encryption protection
Max Operating Distance
30 m
Bundled with
Audio Output
Full size binaural
Foldable
Wireless, wired
Wireless Technology
Bluetooth
Bluetooth Audio Codec
SBC, AAC, LC3
Bluetooth Version
Bluetooth 5.3 LE
Bluetooth Profiles
Hands-Free Profile (HFP), Headset Profile (HSP), Serial Port Profile (SPP), Advanced Audio Distribution Profile (A2DP), Audio/Video Remote Control Profile (AVRCP), Telephony and Media Audio Profile (TMAP), Public Broadcast Profile (PBP)
Sound Output Mode
Stereo
Noise Isolating
Active Noise Cancelling Technology
Advanced ANC
Frequency Response
20 - 20000 Hz
Max Input Power
20 mW
Sensitivity
108.5 dB
Impedance
35 Ohm
Diaphragm
32 mm
Simultaneously Connectable Devices Qty
2
Audio prompts, MultiPoint Technology, Jabra Direct, Google Fast Pair, Auto Pause, Jabra Xpress, Microsoft Swift Pair, HearThrough, digital signal processing, super wideband (SWB), sidetone detection, Auto resume, auto connect
Microphone
Headset microphone
Digital MEMS
6
Sensitivity
-36 dBFS/Pa
Frequency Response
10 - 20000 Hz
Clear Voice Technology
Remote Control
Controls
Connector Type
USB (USB Type-C) , Analogue input (mini-phone 3.5mm)
Internet of Things (IoT)
Communications Technology
Bluetooth 5.3 LE
Carrying case, leaflet, wireless charging pad, 3.5 mm audio cable, USB-C to USB-C cable, Jabra Link 390c USB Adapter
Cable Details
USB-C to USB-C cable - 1.2 m , Mini-phone 3.5 mm to mini-phone 3.5 mm cable
AES, MFI, G616
Sustainability Information
TCO Certified
Headset battery rechargeable - Lithium Ion - - wireless charging
925 mAh
Run Time Details
Continuous talk (ANC OFF): up to 25 hours , Continuous talk (ANC ON): up to 21 hours , Continuous playback (ANC ON): up to 55 hour(s) , Continuous playback (with 10 min charge): up to 10 hours , Continuous playback (ANC OFF): up to 120 hour(s)
Recharge Time
180 min
Shipping Width
18.6 cm
Shipping Depth
22 cm
Shipping Height
6.2 cm
-10 °C
45 °C
Min Storage Temperature
-10 °C
Max Storage Temperature
55 °C
Recommended Use: Portable electronics
Connectivity: Wired
Connectivity: Wireless
Brand: Jabra
