From taking calls around the office to collaborating in cafés, modern work is fast, noisy, and always on the move. The new Jabra Evolve3 75 headset doesn’t just keep up, it makes you unstoppable. At just 180 grams, its sleek design sits gently on the ears for greater comfort and freedom of movement. AI-powered Jabra ClearVoice™ ensures your voice is heard with absolute clarity wherever you are, while Jabra Advanced ANC™ dynamically adjusts to your fit and surroundings for our most powerful noise cancellation yet. And with a pickup accuracy of more than 9 out of 10 words for AI, your prompts land first time—so you get answers instantly and easily without breaking your stride. Evolve3 75 is the perfect balance of voice clarity, immersive sound and freedom of movement, built for how you really work today. Get ready to become unstoppable.
- Jabra Evolve3 75 UC - headset - USB-C via Bluetooth adapter - Zoom Certified - with wireless charging pad
- Product Type
- Headset - Bluetooth - wireless - USB-C via Bluetooth adapter
- Recommended Use
- Portable electronics, computer, conference - communication
- Black
- Headphones Form Factor
- On-ear binaural
- Foldable
- Connectivity Technology
- Wireless
- Wireless Technology
- Bluetooth
- Bluetooth Version
- Bluetooth 5.3 LE
- Sound Output Mode
- Stereo
- Sound Effects
- Spatial Audio
- Audio Specifications
- Frequency Response 20 - 20000 Hz - Sensitivity 108.5 dB
- Impedance
- 35 Ohm
- Max Input Power
- 20 mW
- Active Noise Canceling
- Microphone Operation Mode
- Digital MEMS
- Microphone Noise Cancelling
- Microphones Included
- 6
- Controls
- ANC/HearThrough, power and connection status, voice assistant, next/previous track, play/pause, volume, mute, call
- Intelligent Assistant
- Siri, Google Assistant
- Environmental Standards
- TCO Certified, generation 10, for headsets
- Software Certification
- UC certified, Zoom Certified, Google Meet Certified
- 2-year warranty
- Bundled with
- Wireless charging pad
- Product Type
- 18.7 cm
- 15.1 cm
- 7 cm
- 180 g
- Black
- Body Material
- Metal, PC/ABS
- Headband Material
- Stainless steel, foam, fabric
- Earpad Material
- Dual foam fabric
- Recommended Use
- Wind noise reduction (WNR), sleep mode, up to 8 devices pairing, 360° busylight, in-call LED indicator, AI-ready, replaceable battery, Rapid Charge Technology
- Protection
- Encryption protection
- Max Operating Distance
- 30 m
- Bundled with
Audio Output
- On-ear binaural
- Foldable
- Wireless
- Bluetooth
- Bluetooth Audio Codec
- SBC, AAC, LC3
- Bluetooth Version
- Bluetooth 5.3 LE
- Bluetooth Profiles
- Advanced Audio Distribution Profile (A2DP), Audio/Video Remote Control Profile (AVRCP), Hands-Free Profile (HFP), Headset Profile (HSP), Public Broadcast Profile (PBP), Serial Port Profile (SPP), Telephony and Media Audio Profile (TMAP), Low Energy, Auracast
- Sound Output Mode
- Stereo
- Sound Effects
- Spatial Audio
- Active Noise Cancelling Technology
- Advanced ANC
- 20 - 20000 Hz
- Max Input Power
- 20 mW
- Sensitivity
- 108.5 dB
- Impedance
- 35 Ohm
- Diaphragm
- 32 mm
- Simultaneously Connectable Devices Qty
- 2
- Volume Limiting Function
- Super wideband (SWB), PeakStop technology, IntelliTone technology, HearThrough, Auto Pause, Jabra Direct, Jabra Xpress, Google Fast Pair, sidetone detection
- Audio Output Details
- Multimedia - 20 - 20000 ¦ Communication - 100 - 14500
Microphone
- Form Factor
- Headset microphone
- Digital MEMS
- 6
- Sensitivity
- -36 dBFS/Pa
- 10 - 20000 Hz
- Noise Cancelling
- Noise Cancelling Technology
- Clear Voice Technology
Remote Control
- Controls
Tracking
- Sensors
- On-head detection
- Connector Type
- USB (24 pin USB-C)
Internet of Things (IoT)
- Internet of Things (IoT) Compatible
- Included Accessories
- Carrying case, leaflet, wireless charging pad, USB-C to USB-C cable, Jabra Link 390c USB Adapter
- Cable Details
- USB-C cable - 1.2 m
- G616
Sustainability Information
- TCO Certified
- Battery
- Headset battery rechargeable - Lithium Ion - - wireless charging
- Run Time (Up To)
- 110 hour(s)
- Run Time Details
- Continuous talk (active noise-cancelling/busylight off): up to 22 hours ¦ Continuous talk (active noise-cancelling/busylight on): up to 18 hours ¦ Continuous playback (active noise-cancelling off): up to 110 hours ¦ Continuous playback (active noise-cancelling on): up to 45 hours ¦ Continuous playback (with 10 min fast charge): up to 10 hours ¦ (with 5 min charge): up to 5 hours
- Recharge Time
- 180 min
- Limited warranty - 2 years
- Shipping Width
- 17.6 cm
- Shipping Depth
- 20.5 cm
- Shipping Height
- 5.9 cm
- -10 °C
- 45 °C
- Min Storage Temperature
- -10 °C
- Max Storage Temperature
- 50 °C
