USB-A or USB-C to USB-C cable. Connect and charge your Jabra Evolve2 wireless headset from a USB-A or USB-C enabled device.
Versatile connectivity
Equipped with both USB Type-A and USB-C connectors, this cable offers flexible options for connecting a wide range of devices. Whether you need to link to a legacy system with a USB Type-A port or a modern device featuring a USB-C input, this cable has you covered. -
Durable design
The robust construction of the cable ensures it can withstand the demands of daily use. With male connectors on both ends, it's designed for a secure and reliable connection every time you plug in.
- Jabra - USB-C cable - USB to 24 pin USB-C - 1.2 m
- USB-C cable
- Length
- 1.2 m
- Connector
- 4 pin USB Type A - male
- Connector (Second End)
- 24 pin USB-C - male
- Black
- USB-C cable
- Length
- 1.2 m
- Black
- Connector
