Jabra Evolve2 USB-A to USB-C Cable - Black
Quicklinx: FRLRWS00 Mfr#: 14208-31
Length: 1.2m
18 In Stock
£26.93 ex VAT
£32.31 inc VAT
USB-A or USB-C to USB-C cable. Connect and charge your Jabra Evolve2 wireless headset from a USB-A or USB-C enabled device.
  • Versatile connectivity
    Equipped with both USB Type-A and USB-C connectors, this cable offers flexible options for connecting a wide range of devices. Whether you need to link to a legacy system with a USB Type-A port or a modern device featuring a USB-C input, this cable has you covered.
  • Durable design
    The robust construction of the cable ensures it can withstand the demands of daily use. With male connectors on both ends, it's designed for a secure and reliable connection every time you plug in.
Jabra - USB-C cable - USB to 24 pin USB-C - 1.2 m
USB-C cable
Length
1.2 m
Connector
4 pin USB Type A - male
Connector (Second End)
24 pin USB-C - male
USB-C cable
Length
1.2 m
Connector
24 pin USB-C - male
Length: 1.2m
Brand: Jabra
