Jabra Evolve2 Buds USB-A MS with Wireless Charging Pad
Quicklinx: H9MWWS00 Mfr#: 20797-999-989
Recommended Use: Portable electronics, Computer
Connectivity: Wireless
Earcover : Binaural
Hurry, only 3 left in stock!
£238.64 ex VAT
£286.36 inc VAT
Pitching from the kitchen. Calling from the co-working space. Fitting the status meetings around the daily dog walk. With the right technology, you can work wherever your day takes you. Evolve2 Buds are your portable, pocketable, ultra-convenient slice of office life, when the actual office is nowhere to be seen. Everything you need to make the most of this working on-the-go business, packed into a pair of tiny true wireless earbuds.
  • Beyond the office
    Pitching from the kitchen. Calling from the co-working space. Fitting the status meetings around the daily dog walk. With the right technology, you can work wherever your day takes you. Evolve2 Buds are your portable, pocketable, ultra-convenient slice of office life, when the actual office is nowhere to be seen. Everything you need to make the most of this 'working on the go' business, packed into a pair of tiny true wireless earbuds.
  • Switch it up
    You're mid-Monday-morning-meeting on your laptop when your mobile rings. Ignore? Leave your team meeting? With advanced Bluetooth Multipoint, you don't need to choose. Use your buds for all your calls, staying connected to your laptop and smartphone, with a handy notification if a call comes in on your mobile while you're in a meeting on your laptop. So you can switch, switch and switch again.
  • Choose your tools wisely
    Not all earbuds are created equal. Did you know some of them – like Evolve2 Buds – are actually certified for apps like Google Meet, Microsoft Teams and Zoom?*
  • Get some fresh air
    A walk can work wonders for your mood. Your calls? Not so much. We wanted to fix that, so we created Jabra MultiSensor Voice . It might sound complicated, but all you really need to know is that it opens up a lot more possibilities for where you could take your next call.
  • Your new secret weapon
    Don't underestimate the power of the professional plug-and-play USB adapter that comes with Evolve2 Buds. Just imagine how unstoppable you'll be when you're not saying "hang on, you cut out there", every five minutes. Not to mention the added freedom that comes with knowing you don't have to stay within two metres of your laptop at all times… another coffee anyone?
  • Small and perfectly formed
    We use our massive database of 62,000 ear scans and our unique statistical modeling methods to create tiny earbud designs that fit like they were made for you. And Evolve2 Buds are no different. In fact – this is our smallest true wireless earbud design yet. You know, just in case the office headset vibe isn't quite the look you're going for.
  • They work as hard as you do
    In and out of calls, anywhere but the office and nowhere near a power source – most buds couldn't hack it, but most buds weren't built for hybrid working.
  • Reclaim your thinking space
    Home offices in the school holidays. Co-working spaces. Airport departure lounges. The places you need to work are often noisy. Enter the winning combination of a snug, noise-isolating fit and Active Noise-Cancellation (ANC), to help you find a quiet moment whenever (and wherever) you need one.
  • Hear the important stuff
    Coffee orders, boarding calls or kids with a quick question – there'll always be things you need to hear. So HearThrough makes sure you always do.
  • We've got you
    When you spend a lot of time on calls, you need to protect your hearing. We're part of a company that makes professional, consumer and medical-grade audio technology, so when it comes to preventing hearing damage, you can put your trust in us.
Jabra Evolve2 Buds MS - true wireless earphones with mic - USB-A via Bluetooth adapter
True wireless earphones - Bluetooth - USB-A via Bluetooth adapter
Compatibility
iPhone, Android phone
Recommended Use
Portable electronics, computer
Headphones Form Factor
In-ear
Wireless Technology
Bluetooth
Bluetooth Version
Bluetooth 5.2
Sound Output Mode
Stereo
Sound Effects
HD Voice
Audio Specifications
Frequency Response 20 - 20000 Hz - Sensitivity 98 dB
Impedance
16 Ohm
Active Noise Canceling
Noise Isolating
Microphone Noise Cancelling
Microphones Included
6
Controls
Mute, on/off, answer/end, reject call, voice control
Intelligent Assistant
Alexa
Environmental Standards
TCO Certified Headsets 9
Software Certification
Certified for Microsoft Teams
True wireless earphones - Bluetooth - wireless - USB-A via Bluetooth adapter
Compatibility
Dimensions & Weight Details
Earbud: 1.9 cm x 1.8 cm x 1.6 cm / 5.4 g , Charging case: 7.5 cm x 2.8 cm x 3.8 cm / 52 g
Body Material
Silicone rubber, PC/ABS, gold plated metal, mica-enamelled
Earpad Material
Silicone
Recommended Use
Wireless auto pairing, fast charge, stereo/mono mode, active in-ear pressure relief, easy pairing
Protection
Wind protection, IP57
Max Operating Distance
20 m
Audio Output
In-ear
Wireless
Wireless Technology
Bluetooth
Bluetooth Audio Codec
SBC, AAC
Bluetooth Version
Bluetooth 5.2
Bluetooth Profiles
Hands-Free Profile (HFP), Headset Profile (HSP), Advanced Audio Distribution Profile (A2DP), Audio/Video Remote Control Profile (AVRCP)
Sound Output Mode
Stereo
Sound Effects
HD Voice
Noise Isolating
Active Noise Cancelling Technology
Adjustable noise cancellation
Frequency Response
20 - 20000 Hz
Sensitivity
98 dB
Impedance
16 Ohm
Diaphragm
6 mm
Simultaneously Connectable Devices Qty
2
Voice guidance, PeakStop technology, Jabra Direct, Jabra Xpress, HearThrough, Jabra MultiSensor Voice, Personalised Sound technology, digital signal processing, Apple MFI
Audio Output Details
Communication - 80 - 8000 , Multimedia - 20 - 20000
Microphone
Built-in
6
Frequency Response
80 - 8000 Hz
Noise Cancelling
Battery level indicator
Remote Control
Controls
Tracking
Sensors
Bone sensor, Voice Pickup Unit (VPU), in-ear detection sensor
Internet of Things (IoT)
Alexa
Software Included
Jabra Sound+
Charging case, 3 pairs of EarGels, wireless charging pad, Jabra Link 390a USB Adapter
Cable Details
USB-C to USB-A cable - detachable - 30 cm
Plug and Play, G616
Sustainability Information
TCO Certified
Auto On/Off
Rechargeable - Lithium Ion - - wireless charging
Wireless Charging Standards
Qi
Run Time (Up To)
8 hour(s)
Run Time Details
Continuous playback (active noise-cancelling on) (with included charging case): up to 33 hours , Continuous playback: up to 10 hours , Continuous playback (active noise-cancelling on): up to 8 hours
Standby Time
292 days
Recharge Time
2 hour(s)
Shipping Width
11.5 cm
Shipping Depth
4 cm
Shipping Height
13.7 cm
Recommended Use: Computer
Earcover : Binaural
Brand: Jabra
