Pitching from the kitchen. Calling from the co-working space. Fitting the status meetings around the daily dog walk. With the right technology, you can work wherever your day takes you. Evolve2 Buds are your portable, pocketable, ultra-convenient slice of office life, when the actual office is nowhere to be seen. Everything you need to make the most of this working on-the-go business, packed into a pair of tiny true wireless earbuds.
                Beyond the officePitching from the kitchen. Calling from the co-working space. Fitting the status meetings around the daily dog walk. With the right technology, you can work wherever your day takes you. Evolve2 Buds are your portable, pocketable, ultra-convenient slice of office life, when the actual office is nowhere to be seen. Everything you need to make the most of this 'working on the go' business, packed into a pair of tiny true wireless earbuds.
                Switch it upYou're mid-Monday-morning-meeting on your laptop when your mobile rings. Ignore? Leave your team meeting? With advanced Bluetooth Multipoint, you don't need to choose. Use your buds for all your calls, staying connected to your laptop and smartphone, with a handy notification if a call comes in on your mobile while you're in a meeting on your laptop. So you can switch, switch and switch again.
                Choose your tools wiselyNot all earbuds are created equal. Did you know some of them – like Evolve2 Buds – are actually certified for apps like Google Meet, Microsoft Teams and Zoom?*
                Get some fresh airA walk can work wonders for your mood. Your calls? Not so much. We wanted to fix that, so we created Jabra MultiSensor Voice . It might sound complicated, but all you really need to know is that it opens up a lot more possibilities for where you could take your next call.
                Your new secret weaponDon't underestimate the power of the professional plug-and-play USB adapter that comes with Evolve2 Buds. Just imagine how unstoppable you'll be when you're not saying "hang on, you cut out there", every five minutes. Not to mention the added freedom that comes with knowing you don't have to stay within two metres of your laptop at all times… another coffee anyone?
                Small and perfectly formedWe use our massive database of 62,000 ear scans and our unique statistical modeling methods to create tiny earbud designs that fit like they were made for you. And Evolve2 Buds are no different. In fact – this is our smallest true wireless earbud design yet. You know, just in case the office headset vibe isn't quite the look you're going for.
                They work as hard as you doIn and out of calls, anywhere but the office and nowhere near a power source – most buds couldn't hack it, but most buds weren't built for hybrid working.
                Reclaim your thinking spaceHome offices in the school holidays. Co-working spaces. Airport departure lounges. The places you need to work are often noisy. Enter the winning combination of a snug, noise-isolating fit and Active Noise-Cancellation (ANC), to help you find a quiet moment whenever (and wherever) you need one.
                Hear the important stuffCoffee orders, boarding calls or kids with a quick question – there'll always be things you need to hear. So HearThrough makes sure you always do.
                We've got youWhen you spend a lot of time on calls, you need to protect your hearing. We're part of a company that makes professional, consumer and medical-grade audio technology, so when it comes to preventing hearing damage, you can put your trust in us.
- Jabra Evolve2 Buds MS - true wireless earphones with mic - USB-C via Bluetooth adapter
- Product Type
- True wireless earphones - Bluetooth - USB-C via Bluetooth adapter
- Compatibility
- iPhone, Android phone
- Recommended Use
- Portable electronics, computer
- Black
- Headphones Form Factor
- In-ear
- Wireless Technology
- Bluetooth
- Bluetooth Version
- Bluetooth 5.2
- Sound Output Mode
- Stereo
- Sound Effects
- HD Voice
- Audio Specifications
- Frequency Response 20 - 20000 Hz - Sensitivity 98 dB
- Impedance
- 16 Ohm
- Active Noise Canceling
- Noise Isolating
- Microphone Noise Cancelling
- Microphones Included
- 6
- Controls
- Mute, on/off, answer/end, reject call, voice control
- Intelligent Assistant
- Alexa
- Environmental Standards
- TCO Certified Headsets 9
- Software Certification
- Certified for Microsoft Teams
- 2-year warranty
- Product Type
- True wireless earphones - Bluetooth - wireless - USB-C via Bluetooth adapter
- Compatibility
- Dimensions & Weight Details
- Earbud: 1.9 cm x 1.8 cm x 1.6 cm / 5.4 g , Charging case: 7.5 cm x 2.8 cm x 3.8 cm / 52 g
- Black
- Body Material
- Silicone rubber, PC/ABS, gold plated metal, mica-enamelled
- Earpad Material
- Silicone
- Recommended Use
- Wireless auto pairing, fast charge, stereo/mono mode, active in-ear pressure relief, easy pairing
- Protection
- Wind protection, IP57
- Max Operating Distance
- 20 m
Audio Output
- In-ear
- Connectivity Technology
- Wireless
- Bluetooth
- Bluetooth Audio Codec
- SBC, AAC
- Bluetooth Version
- Bluetooth 5.2
- Bluetooth Profiles
- Hands-Free Profile (HFP), Headset Profile (HSP), Advanced Audio Distribution Profile (A2DP), Audio/Video Remote Control Profile (AVRCP)
- Sound Output Mode
- Stereo
- Sound Effects
- HD Voice
- Noise Isolating
- Active Noise Cancelling Technology
- Adjustable noise cancellation
- 20 - 20000 Hz
- Sensitivity
- 98 dB
- Impedance
- 16 Ohm
- Diaphragm
- 6 mm
- Simultaneously Connectable Devices Qty
- 2
- Voice guidance, PeakStop technology, Jabra Direct, Jabra Xpress, HearThrough, Jabra MultiSensor Voice, Personalised Sound technology, digital signal processing, Apple MFI
- Audio Output Details
- Communication - 80 - 8000 , Multimedia - 20 - 20000
Microphone
- Form Factor
- Built-in
- 6
- 80 - 8000 Hz
- Noise Cancelling
- Battery level indicator
Remote Control
- Controls
Tracking
- Sensors
- Bone sensor, Voice Pickup Unit (VPU), in-ear detection sensor
Internet of Things (IoT)
- Internet of Things (IoT) Compatible
- Alexa
- Software Included
- Jabra Sound+
- Included Accessories
- Charging case, 3 pairs of EarGels, USB-A to USB-C adapter, Jabra Link 390c USB Adapter
- Cable Details
- USB-C to USB-A cable - detachable - 30 cm
- Plug and Play, G616
Sustainability Information
- TCO Certified
- Auto On/Off
- Battery
- Rechargeable - Lithium Ion - - wireless charging
- Wireless Charging Standards
- Qi
- Run Time (Up To)
- 8 hour(s)
- Run Time Details
- Continuous playback (active noise-cancelling on) (with included charging case): up to 33 hours , Continuous playback: up to 10 hours , Continuous playback (active noise-cancelling on): up to 8 hours
- Standby Time
- 292 days
- Recharge Time
- 2 hour(s)
- Limited warranty - 2 years
- Shipping Width
- 11.5 cm
- Shipping Depth
- 4 cm
- Shipping Height
- 13.7 cm
