Our checkout area is closed for maintenance, but should be back online soon. We apologise for any inconvenience caused
Jabra Evolve2 85 USB-C MS Stereo Headset with Desk Stand - Black
Quicklinx: FRKCWS00 Mfr#: 28599-999-889
Recommended Use: Computer, Portable electronics
Connectivity: Wired, Wireless
Earcover : Binaural
£287.69 ex VAT
£345.22 inc VAT
They set out to create instant quiet, anywhere. The result is a world-class professional headset with cutting-edge digital hybrid Active Noise Cancellation(ANC), powered by the most advanced digital chipset ever, and designed for incredible noise isolation; just put it on for instant immersion in your thoughts. It's time to change the game. Welcome to the new standard.
They've taken busylight to a whole new level, making it visible from any direction. The red light is automatically activated when you're on a call or in a meeting, or you can activate it yourself at the touch of a button. So, even when you're right in the middle of everything, your busylight will protect you from all angles, and all interruptions. It's like having a built-in security guard for your concentration.
They've built this headset with powerful leak-tolerant 40mm speakers. Factor in advanced digital chipset and the latest AAC codec, and your music will be sounding better than ever. Good things come to those who wait. This is the audio experience you've been waiting for.
They know that being heard and understood with absolute clarity keeps your calls seamless and professional. So, they took the incredible call performance of world-leading Evolve Series, and they made it even better by building in 10 microphones(yes, 10), powered by that advanced digital chipset they keep talking about, for outstanding call quality, every time. Because when you're making an important call, clarity is everything.
When you finally find a headset that you just can't do without, it's good to know you don't have to. They've used the advanced battery efficiency technology to squeeze every last minute of juice out of this powerful headset.
They took biometric measurements of hundreds of heads to create a perfect design that adjusts to fit every size and shape. Then, they added soft memory foam ear cushions to make it supremely comfortable; so comfortable, you'll forget it's even there. Finally, they assembled it using durable, premium materials. It's comfort that's in a class of its own.
Move seamlessly from the office to on-the-go, with a contemporary casual design and a discrete hidden boom arm that still guarantees exceptional professional sounding calls, even when tucked away. So when you're on the go, only you'll know you're working.
  • Hear yourself think
    We set out to create instant quiet, anywhere. The result is a world-class professional headset with cutting-edge digital hybrid Active Noise-Cancellation (ANC), powered by our most advanced digital chipset ever and designed for incredible noise isolation; just put it on for instant immersion in your thoughts. It's time to change the game. Welcome to the new standard.
  • Don't hide when you're in your stride
    We've taken our busylight to a whole new level, making it visible from any direction. The red light is automatically activated when you're on a call or in a meeting or you can activate it yourself at the touch of a button. So, even when you're right in the middle of everything, your busylight will protect you from all angles, and all interruptions. It's like having a built-in security guard for your concentration.
  • Bigger speakers
    We've built this headset with powerful leak-tolerant 40mm speakers. Factor in our advanced digital chipset and the latest AAC codec and your music will be sounding better than ever. Good things come to those who wait. This is the audio experience you've been waiting for.
  • It's your call…
    We know that being heard and understood with absolute clarity keeps your calls seamless and professional. So, we took the incredible call performance of our world-leading Evolve Series and we made it even better by building in 10 microphones (yes, 10), powered by that advanced digital chipset we keep talking about, for outstanding call quality, every time. Because when you're making an important call, clarity is everything.
  • UC-certified means UC-satisfied
    Satisfaction guaranteed isn't something you hear very often these days, but we're bringing it back; Evolve2 85 works with all leading Unified Communications (UC) platforms, for truly seamless collaboration. If your UC platform of choice is Microsoft Teams, the Teams-certified variant is perfectly adapted and optimised to give you the best experience with the platform.
  • Long week?
    When you finally find a headset that you just can't do without, it's good to know you don't have to. We've used our advanced battery efficiency technology to squeeze every last minute of juice out of this powerful headset. The result is an industry-leading 37-hour battery life (powered by that mighty little chipset again). And because we like to cover all bases, there's always the handy charging stand – just in case. Rest assured; Evolve2 85 will get you through the week.
  • Upgrade to business class
    We took biometric measurements of hundreds of heads to create a perfect design that adjusts to fit every size and shape. Then, we added soft memory foam ear cushions to make it supremely comfortable; so comfortable, you'll forget it's even there. Finally, we assembled it using durable, premium materials. It's comfort that's in a class of its own.
  • Thinking outside the box
    As far as things in boxes go, this is kind of a big deal. Before you've even unboxed it, you're holding a pioneering piece of tech that's leagues ahead of any other headset. But because we have one eye on the future, firmware upgrades and value packs are already on the way to boost it even further. If you think it's great now, just wait…
  • Business
    Move seamlessly from the office to on-the-go, with a contemporary casual design and a discrete hidden boom-arm that still guarantees exceptional professional sounding calls, even when tucked away. So when you're on the go, only you'll know you're working.
  • Hear yourself think.
    We set out to create instant quiet, anywhere. The result is a world‐class professional headset with cutting‐edge digital hybrid Active Noise‐Cancellation (ANC), powered by our most advanced digital chipset ever and designed for incredible noise isolation; just put it on for instant immersion in your thoughts. It’s time to change the game. Welcome to the new standard.
  • Don’t hide when you’re in your stride.
    We’ve taken our busylight to a whole new level, making it visible from any direction. The red light is automatically activated when you’re on a call or in a meeting or you can activate it yourself at the touch of a button. So, even when you’re right in the middle of everything, your busylight will protect you from all angles, and all interruptions. It’s like having a built‐in security guard for your concentration.
  • Bigger speakers. Better sound. Boom.
    We’ve built this headset with powerful leak‐tolerant 40mm speakers. Factor in our advanced digital chipset and the latest AAC codec and your music will be sounding better than ever. Good things come to those who wait. This is the audio experience you’ve been waiting for.
  • It’s your call…
    We know that being heard and understood with absolute clarity keeps your calls seamless and professional. So, we took the incredible call performance of our world‐leading Evolve Series and we made it even better by building in 10 microphones (yes, 10), powered by that advanced digital chipset we keep talking about, for outstanding call quality, every time. Because when you’re making an important call, clarity is everything.
  • UC‐certified means UC‐satisfied.
    Satisfaction guaranteed isn’t something you hear very often these days, but we’re bringing it back; Evolve2 85 works with all leading Unified Communications (UC) platforms, for truly seamless collaboration. If your UC platform of choice is Microsoft Teams, the Teams‐certified variant is perfectly adapted and optimised to give you the best experience with the platform.
  • Long week? We’ve got you covered.
    When you finally find a headset that you just can’t do without, it’s good to know you don’t have to. We’ve used our advanced battery efficiency technology to squeeze every last minute of juice out of this powerful headset. The result is an industry‐leading 37‐hour battery life (powered by that mighty little chipset again). And because we like to cover all bases, there’s always the handy charging stand – just in case. Rest assured; Evolve2 85 will get you through the week.
  • Upgrade to business class.
    We took biometric measurements of hundreds of heads to create a perfect design that adjusts to fit every size and shape. Then, we added soft memory foam ear cushions to make it supremely comfortable; so comfortable, you’ll forget it’s even there. Finally, we assembled it using durable, premium materials. It’s comfort that’s in a class of its own.
  • Thinking outside the box.
    As far as things in boxes go, this is kind of a big deal. Before you’ve even unboxed it, you’re holding a pioneering piece of tech that’s leagues ahead of any other headset. But because we have one eye on the future, firmware upgrades and value packs are already on the way to boost it even further. If you think it’s great now, just wait…
  • Business. Casual.
    Move seamlessly from the office to on‐the‐go, with a contemporary casual design and a discrete hidden boom‐arm that still guarantees exceptional professional sounding calls, even when tucked away. So when you’re on the go, only you’ll know you’re working.
Jabra Evolve2 85 MS Stereo - headset - 3.5 mm jack
Headset - Bluetooth - wireless, wired - 3.5 mm jack
Compatibility
iPhone, Android phone, Mac, Windows
Recommended Use
Portable electronics, computer - communication
Additional Functions
DSP
Headphones Form Factor
Full size
Wireless, wired
Wireless Technology
Bluetooth
Bluetooth Version
Bluetooth 5.0
Sound Output Mode
Stereo
Audio Specifications
Frequency Response 20 - 20000 Hz - Sensitivity 117 dB
Max Input Power
50 mW
Active Noise Canceling
Noise Isolating
Microphone
Boom
Controls
Volume, mute button, answer/end, play/pause, next/previous track, voice assistant
Environmental Standards
TCO Certified Headsets 9
Software Certification
Certified for Microsoft Teams
Compatibility
DSP
19.86 cm
7.73 cm
16 cm
286 g
Headband Material
Foam, leatherette
Earpad Material
Leatherette, foam
Recommended Use
Max Operating Distance
30 m
Audio Output
Full size
Wireless, wired
Wireless Technology
Bluetooth
Bluetooth Audio Codec
AAC
Bluetooth Version
Bluetooth 5.0
Bluetooth Profiles
Hands-Free Profile (HFP), Headset Profile (HSP), Serial Port Profile (SPP), Advanced Audio Distribution Profile (A2DP), Audio/Video Remote Control Profile (AVRCP), Phonebook Access Profile (PBAP)
Sound Output Mode
Stereo
Noise Isolating
Active Noise Cancelling Technology
Hybrid Active Noise Cancelling
Frequency Response
20 - 20000 Hz
Max Input Power
50 mW
Sensitivity
117 dB
Diaphragm
40 mm
Simultaneously Connectable Devices Qty
2
Busy light, SafeTone technology, Jabra Direct
Microphone
Boom
Headset microphone
Sensitivity
-35 dBV/Pascal
Frequency Response
5 - 20000 Hz
Remote Control
Controls
Tracking
Sensors
On-ear detection
Connector Type
Headset (mini-phone 3.5mm)
Cable
Detachable Cable
Charging stand, carrying bag, Inflight adapter, 3.5 mm audio cable, Jabra Link 390c USB Adapter
Cable Details
Audio cable - detachable - 1.2 m
Sustainability Information
TCO Certified
Headset battery rechargeable - Lithium Ion
Run Time (Up To)
37 hour(s)
Run Time Details
Continuous playback: up to 37 hours , Continuous playback (noise cancelling ON): up to 32 hours , Continuous talk: up to 30 hours , Continuous talk (noise cancelling ON): up to 20 hours
Recharge Time
2.5 hour(s)
Shipping Width
22.7 cm
Shipping Depth
9.2 cm
Shipping Height
18.85 cm
FRKC Jabra Link 370 USB BT Adapter, MS Teams In Stock £53.21
FRKC Jabra Evolve2 85 Charging Stand USB-C - Black In Stock £68.29
FRKC Jabra Evolve2 85 Ear Cushion Kit Black Version - 1 Pair In Stock £24.14
Recommended Use: Portable electronics
Connectivity: Wired
Connectivity: Wireless
Earcover : Binaural
Brand: Jabra
