Jabra Evolve2 75 is ideal for those who need maximum flexibility. An ergonomic, biometrically-measured headset with outstanding audio technology and fully adjustable Jabra Advanced Active Noise-Cancellation , for superior call and music performance in complete comfort. Everywhere.
The new standard for hybrid working
From the first call of the day to the last train home, this clever headset has been specifically engineered to keep you connected and productive. Whatever your day throws at you. So, whether you're dialing in from a noisy home, hot-desking in a shared workspace or trying to concentrate in a busy open office, the Evolve2 75 is perfectly engineered for your needs. Have we got your attention? Then step into our office… -
Make yourself at home
Ready for a whole new standard of comfort? We've created a revolutionary new dual-foam technology, with an ergonomic earcup design. Featuring a re-engineered leatherette ear cushion pattern for improved ventilation, it'll keep you comfortable from the first call to the last. Our engineers spent a lot of time examining different weights, consistencies and densities of memory foam to optimize audio performance. And they made an amazing comfort breakthrough at the same time. By combining hard foam for the exterior and soft foam for the interior of the ear cushions, we can deliver incredible noise isolation and the ultimate all-day comfort. So you get even better Active Noise-Cancellation (ANC) performance in a headset you can keep wearing as long as you like. It's time to settle into a whole new standard of comfort. -
Keep it professional
Because hybrid working can be noisy, we've engineered Evolve2 75 with 8 strategically-placed microphones and our advanced beamforming technology. So even when the kids are home, the train's crowded or the office is a little busy, with our world-leading call technology, they'll hear you and not your surroundings. Evolve2 75 meets Microsoft's Open Office requirements, making it the ideal choice for busy open-plan workspaces. Our advanced triple digital chipset powers a ground-breaking new Jabra algorithm, which improves the differentiation between voice and background noise to make your calls even sharper Evolve2 75 keeps the background noise in the background – and off your calls. -
Best-in-class
Our Evolve Series is already miles ahead when it comes to industry-leading professional-grade call performance, but Evolve2 75 takes best-in-class. With a re-engineered microphone boom-arm that's 33% shorter than Evolve 75, it delivers the world-leading call performance Jabra headsets are so famous for. In Performance Mode, with the microphone boom-arm down, it's specifically optimised for outstanding calls in open-plan offices and other noisy places, and meets Microsoft's Open Office requirements. And when you're on the go, Discreet Mode, with its hide-away design, makes it completely invisible, while still delivering reliably clear calls. With Evolve2 75, anywhere works. -
Concentration mode: activated
Sometimes you have to take calls or find focus in less-than-ideal environments. But with our fully adjustable Jabra Advanced Active Noise-Cancellation (ANC) , you don't need to worry about how (and where) you work. Use the Sound+ app to select your level of noise-cancellation, and let the advanced feedforward and feedback dual hybrid ANC do its thing to protect your focus. From the train, to the street, to the café, to the airport and back to the office again. Evolve2 75 is engineered to help you concentrate – wherever you are. -
Three advanced chipsets
All the outstanding (and we mean outstanding) features in Evolve2 75 are powered by an advanced ecosystem of three powerful digital chipsets. These work in tandem to make Evolve2 75 faster, more powerful and more intelligent than ever before. Incredible processing power = incredible productivity. -
As flexible as you are
Evolve2 75 is available in a Microsoft Teams-certified variant and a UC variant, which is certified for Google Meet and Zoom to ensure a seamless collaboration experience. It's also optimised for other leading UC platforms, so you can be confident that however you keep in touch with your team, this trusted device will keep the collaboration going all day. -
Protect your focus zone
On a call? No problem. We've studied open office behaviour and used the results to optimise the busylight on Evolve2 75, making it even more visible*, allowing it to be seen from more angles. Now, your teammates can make a quick U-turn before you have to start mouthing 'I'm on a call' at them. It's good to know you can stop interruptions before they happen. *when compared to the Evolve 75 model. -
Stay flexible
Time for a coffee. With outstanding call performance within a 30-metres wireless range, you can grab one even though you're on a call (just don't forget to go on mute). And with flexible connectivity, you can connect to both your laptop and your smartphone. So you can walk even further from your desk without getting disconnected. Evolve2 75 gives you the flexible work-day freedom you need. -
Find your rhythm
As world leaders in professional-grade sound, we never underestimate the power of great audio to keep your day flowing smoothly. And we've set a new standard all over again with Evolve2 75. Powerful leak-tolerant 40mm speakers, combined with our revolutionary new dual-foam discovery, deliver crisp, clear audio for both your calls and your music. The latest AAC codecs and our unique MySound technology (which tailors your sound to your individual hearing profile) will have your music sounding better than you could ever imagine. You can even fine-tune it further using the customisable EQ. So whether you're dialing into a Monday morning check-in or listening to your Monday Motivation playlist, Evolve2 75 is engineered to bring the sound quality that powers your day. Whatever you're doing, Evolve2 75 helps you find the rhythm that works for you. -
Let's hear it
Noise-cancellation is great, but sometimes you need to tap back into reality for a second. From platform announcements to ordering a coffee, if you tap your HearThrough button, you can hear it all without taking off your headset. HearThrough uses the built-in microphones to let the outside in, giving you the freedom to tap into conversations or tune into your surroundings at the touch of a button. HearThrough keeps the real world at your fingertips. -
Your headset
With the companion apps for Evolve2 75, you can personalise almost everything about your headset, to make it uniquely yours. Use the Sound+ app to adjust your ANC & HearThrough, fine-tune your sound with MySound & the customisable equaliser, adjust call settings and upgrade firmware from your mobile. Using more than one Jabra headset? Use the Jabra Direct app on your PC for a complete overview and firmware upgrades for all your devices. We've even given it a shiny new look and added more great features. Because we don't believe headsets should be 'one size fits all'. -
Designed with a fit-first approach
From the first call to the last, Evolve2 75 delivers a whole new standard of comfort. That's because we took a completely new approach to the design, using biometric measurements from hundreds of heads to get the fit just right. Using a simulation head (and hundreds of real-life test subjects), we made sure we'd crafted a solution that really fits, before moving onto the Danish design. The perfect fit. Designed for you. -
All work
When no two days are the same, you need to know your headset can handle the pace. We used our advanced battery efficiency technology to optimise the performance of Evolve2 75, delivering up to 25 hours of talk-time or 36 hours of music time, on a single charge. We've also optimised our fast charge feature, delivering an impressive 4 hours of battery in just fifteen minutes of charging. So you can stretch that week-long battery life out to cover your downtime too. Extended battery. Extended possibilities.
- Jabra Evolve2 75 - headset - USB-A - with charging stand
- Product Type
- Headset - Bluetooth - wireless - USB-A
- Compatibility
- iPhone, Android phone, Mac, Windows
- Recommended Use
- Portable electronics, computer - communication
- Additional Functions
- DSP
- Black
- Headphones Form Factor
- On-ear
- Connectivity Technology
- Wireless
- Wireless Technology
- Bluetooth
- Bluetooth Version
- Bluetooth 5.2
- Sound Output Mode
- Stereo
- Sound Effects
- Power Bass, HD Voice
- Audio Specifications
- Frequency Response 20 - 20000 Hz - Sensitivity 84 dB/mW
- Impedance
- 16 Ohm
- Max Input Power
- 30 mW
- Active Noise Canceling
- Noise Isolating
- Microphone
- Boom
- Microphone Operation Mode
- Beamforming
- Microphones Included
- 8
- Controls
- Mute button, reject call, voice assistant, forward call, answer call
- Intelligent Assistant
- Alexa built-in
- Environmental Standards
- TCO Certified Headsets 9
- Software Certification
- Certified for Microsoft Teams
- 2-year warranty
- Bundled with
- Charging stand
- Product Type
- Compatibility
- DSP
- Dimensions & Weight Details
- Handset: 14.5 cm x 19 cm x 6.7 cm / 197 g
- Black
- Headband Material
- Foam, leatherette, metal
- Earpad Material
- Leatherette
- Recommended Use
- Max Operating Distance
- 30 m
- Bundled with
- Charging stand
Audio Output
- On-ear
- Wireless
- Bluetooth
- Bluetooth Audio Codec
- SBC, AAC
- Bluetooth Version
- Bluetooth 5.2
- Bluetooth Profiles
- Hands-Free Profile (HFP), Headset Profile (HSP), Serial Port Profile (SPP), Advanced Audio Distribution Profile (A2DP), Audio/Video Remote Control Profile (AVRCP), Phonebook Access Profile (PBAP)
- Sound Output Mode
- Stereo
- Sound Effects
- Noise Isolating
- Active Noise Cancelling Technology
- Advanced ANC
- 20 - 20000 Hz
- Max Input Power
- 30 mW
- Sensitivity
- 84 dB/mW
- Impedance
- 16 Ohm
- Diaphragm
- 40 mm
- Simultaneously Connectable Devices Qty
- 2
- Busy light, SafeTone technology, PeakStop technology, Jabra Direct, HearThrough
Microphone
- Boom
- Form Factor
- Headset microphone
- Beamforming
- 8
- Sensitivity
- -35 dBV/Pascal
- 5 - 20000 Hz
Remote Control
- Controls
Tracking
- Sensors
- On-ear detection
- Connector Type
- USB (USB Type-A)
Cable
- Detachable Cable
- Cable Length
- 1.2 m
Internet of Things (IoT)
- Internet of Things (IoT) Compatible
- Alexa built-in
- Included Accessories
- Charging stand, carrying bag, USB-C charging cable, Jabra Link 390 USB Adapter
- Cable Details
- USB-C charge cable - detachable - 1.2 m
- Plug and Play, MFI, G616
Sustainability Information
- TCO Certified
- Battery
- Headset battery rechargeable - Lithium Ion
- Run Time (Up To)
- 36 hour(s)
- Run Time Details
- Continuous playback (noise cancelling OFF): up to 36 hours , Continuous playback (noise cancelling ON): up to 33 hours , Continuous talk (noise cancelling OFF): up to 25 hours , Continuous talk (noise cancelling ON): up to 19 hours
- Recharge Time
- 160 min
- Limited warranty - 2 years
- Shipping Width
- 19.9 cm
- Shipping Depth
- 23.8 cm
- Shipping Height
- 7.5 cm
