Jabra Evolve2 65 USB-A UC Mono Headset with Desk Stand - Beige
Quicklinx: FRKZWS00 Mfr#: 26599-889-988
Recommended Use: Phone, Computer, Portable electronics, Phone
Connectivity: Wireless
£151.65 ex VAT
£181.98 inc VAT
Whether you're working in the office or on the go, background noise can really disrupt your flow. Put on your Evolve2 65 and feel the noise around you instantly fade, as the isolating foam oval ear cushions and pioneering new angled earcup design work to effectively block out your surroundings, giving you passive noise cancellation like you've never experienced. You could say it's like a portable quiet room for your head.
  • Great call.
    Outstanding outcomes require outstanding call performance, and seamless, professional audio makes all the difference. We took the incredible call performance of our world‐leading Evolve Series and we made it even better, building in three strategically placed powerful professional microphones and adding our advanced digital chipset and latest signal processing technology. The result is outstanding call quality, every time. It’s not just a great call. It’s the new standard of great calls.
  • UC‐certified means UC‐satisfied.
    Satisfaction guaranteed isn’t something you hear very often these days, but we’re bringing it back; Evolve2 65 works with all leading Unified Communications (UC) platforms, for truly seamless collaboration. If your UC platform of choice is Microsoft Teams, the Teams‐certified variant is perfectly adapted and optimized to give you the best experience with the platform.
  • Music so good, you can feel it.
    We’ve built this headset with powerful leak‐tolerant 40mm speakers and powered it with our most advanced digital chipset ever. With Evolve, we brought you great music while you work. With Evolve2, we’re taking audio quality to a whole new level. It’s a professional headset, but not as you know it.
  • Soundproof your ears.
    Whether you’re working in the office or on the go, background noise can really disrupt your flow. Put on your Evolve2 65 and feel the noise around you instantly fade, as the isolating foam oval ear cushions and pioneering new angled earcup design work to effectively block out your surroundings, giving you passive noise‐cancellation like you’ve never experienced. You could say it’s like a portable quiet room for your head.
  • Don’t hide when you’re in your stride.
    We’ve taken our busylight to a whole new level, making it visible from any direction. The red light is automatically activated when you’re on a call or in a meeting, or you can activate it yourself at the touch of a button. So, even when you’re right in the middle of everything, your busylight will protect you from all angles, and all interruptions. It’s like having a built‐in security guard for your concentration.
  • Battery for days.
    Whether you’re in and out of meetings, walking the corridors or working remotely, it’s good to know your headset can handle the pace. Our advanced battery efficiency technology and that incredible little chipset have helped us to squeeze an industry‐leading 37 hours* of juice out of this powerful wireless headset. But we’ve got you covered with the handy charging stand as well, just in case.
  • True comfort. True luxury.
    We set out to create a wireless headset that would feel so great, you’d forget you were even wearing it. We designed the perfect shape using biometric measurements from hundreds of heads. Then we added soft memory foam cushions that mold to your ear’s natural contours. Finally, we assembled it using durable, premium materials. Because when it comes to your headset, true luxury is forgetting it’s there.
  • Thinking outside the box.
    As far as things in boxes go, this is kind of a big deal. Before you’ve even unboxed it, you’re holding a pioneering piece of tech that’s leagues ahead of any other headset. But because we have one eye on the future, firmware upgrades and value packs are already on the way to boost it even further. If you think it’s great now, just wait…
Jabra Evolve2 65 UC Mono - headset - with charging stand
Headset - Bluetooth - wireless - USB-A
Recommended Use
Portable electronics, phone, computer - communication
Additional Functions
DSP
Beige
Headphones Form Factor
On-ear - convertible
Wireless
Wireless Technology
Bluetooth
Bluetooth Version
Bluetooth 5.0
Sound Output Mode
Mono
Noise Isolating
Microphone
Boom
Controls
Volume, mute button, answer/end
Environmental Standards
TCO Certified Headsets 9
Bundled with
Charging stand
DSP
99.2 g
Beige
Earpad Material
Leatherette, memory foam
Recommended Use
Max Operating Distance
30 m
Bundled with
Charging stand
Audio Output
Wireless
Wireless Technology
Bluetooth
Bluetooth Version
Bluetooth 5.0
Bluetooth Profiles
Headset Profile (HSP), Advanced Audio Distribution Profile (A2DP), Audio/Video Remote Control Profile (AVRCP)
Sound Output Mode
Mono
Noise Isolating
Diaphragm
40 mm
Simultaneously Connectable Devices Qty
2
Voice control, Busy light, PeakStop technology, Jabra Direct
Microphone
Boom
Headset microphone
Remote Control
Controls
Connector Type
Headset (4 PIN USB Type A)
Cable
Detachable Cable
Carrying case, USB cable, USB dongle
Cable Details
USB cable - detachable
G616
Sustainability Information
TCO Certified
Headset battery rechargeable
Run Time (Up To)
24 hour(s)
Standby Time
1600 hours
Recharge Time
1.5 hour(s)
FRKZ Jabra Link 370 USB BT Adapter, MS Teams In Stock £53.98
FRKZ Jabra Evolve2 65 Desk Stand USB-A - Black In Stock £64.38
FRKZ Jabra Ear Cushions for Evolve2 65/40 (6pcs) - Black In Stock £68.29
Recommended Use: Computer
Recommended Use: Portable electronics
Brand: Jabra
