Professional quality calls anywhere. Motivational playlists before an important presentation. Meditative sounds to help you focus. When you work in hybrid mode, your days can be very busy, so it's important that your headphones keep up with you.
The Evolve2 55 are specifically designed to go with you everywhere. They fit your every need, giving you a high-quality calling and music listening experience with Advanced Active Noise Cancellation, noise-canceling microphones and custom 28mm speakers, plus a high level of comfort with revolutionary Jabra Air Comfort technology.
Fit for every purpose
Professional calls from your spare bedroom. Motivational playlists before a big pitch. Meditative sounds when it's time to focus. Hybrid work days have a lot going on, so it's important your headset can keep up. Evolve2 55 is specially engineered to go with your flow. It's ready to work whichever way you do, delivering professional sound to your calls and your music, with powerful Active Noise-Cancellation (ANC), noise-cancelling mics and 28mm custom speakers - all while treating your head to best-in-class comfort* with our revolutionary Jabra Air Comfort technology. Do it all, with a headset designed to do it all *Class is defined as competitors in the same price range. Claim applies to stereo variant. Refer to jabra.co.uk/commercial-claims . -
There's something in the air…
Our engineers spent years perfecting our new game-changing Jabra Air Comfort technology to create this incredible best-in-class comfort*. -
It's oh-so-quiet
We've all had one of those days. A buzzer-happy delivery driver arriving mid-conference call. The kids screeching about snacks just as you're about to seal the deal. Your dog barking in the background of that crucial client chat. Enter Evolve2 55. Its powerful Active Noise Cancellation (ANC) has a novelty acoustic chamber design and a specially-designed chipset, plus 2 premium noise-cancelling microphones, to effectively silence your surroundings. So you can get on with making hybrid work, work for you. -
We hear you
Bright ideas. Words of wisdom. Crucial comments. Whatever you've got to say, Evolve2 55 makes sure you sound professional when you say it. A clever chipset powers its speech-separating, noise-cancelling algorithm and 2 premium microphones, to effectively filter out background distractions. So whoever you're talking to hears you – and only you – as clearly as if you're sitting next to them. -
All work and all play
Evolve2 55 does it all, a bit like you. Stay work-ready with efficiency-boosting tech and a busylight to protect your focus. Taking a moment to recharge between meetings? Immerse yourself in optimised music and media with rich full sound from 28mm custom speakers. Looking for the next flight to Copenhagen (or just the quickest route home)? Tap to hear all the answers from your chosen voice assistant. Even the battery works as hard as you do - we've made it last longer, so you can listen to whatever music keeps you going without constantly having to stop and charge*. With Evolve2 55 you're ready for anything. *up to 10 hours talk time with ANC on and busylight on and up to 18 hours listening time with ANC off and busylight off. -
Ready, headset, go
We know your time is valuable, so we've made Evolve2 55 easy and lightning-fast to use. We're talking instant out-of-the-box plug & play, walk-and-talk-on-the-way simple. Sitting down at your desk? Just plug and play with the pre-paired USB adapter for your laptop. Out and about? Bluetooth connects to your phone instantly. A wireless range of up to 30m/100ft gives you even more flexibility - ideal for brewing your thoughts and your coffee during a call. -
As flexible as you are
Evolve2 55 is available in a Microsoft Teams-certified variant and a UC variant, which is certified for Google Meet and Zoom to ensure a seamless collaboration experience. It's also optimised for other leading UC platforms, so you can be confident that however you keep in touch with your team, this trusted device will keep the collaboration going all day. -
Work-anywhere professionalism, with noise-cancelling microphone technology
Work-anywhere professionalism, with noise-cancelling microphone technology.
- Jabra Evolve2 55 UC Stereo - headset - USB-A
- Product Type
- Headset - Bluetooth - wireless - USB-A
- Recommended Use
- Portable electronics, phone, computer - communication
- Black
- Headphones Form Factor
- On-ear
- Connectivity Technology
- Wireless
- Wireless Technology
- Bluetooth
- Bluetooth Version
- Bluetooth 5.2
- Sound Output Mode
- Stereo
- Audio Specifications
- Frequency Response 20 - 20000 Hz
- Max Input Power
- 30 mW
- Active Noise Canceling
- Microphone
- Boom
- Microphones Included
- 3
- Controls
- Mute, volume, power on/off, busylight, call
- Environmental Standards
- TCO Certified Headsets 9
- Software Certification
- Optimised for UC
- 2-year warranty
- Product Type
- 18.5 cm
- 17.5 cm
- 6.5 cm
- 130 g
- Black
- Earpad Material
- Leatherette, foam
- Recommended Use
- LED indicator
- Protection
- Hearing protection
- Max Operating Distance
- 30 m
Audio Output
- On-ear
- Wireless
- Bluetooth
- Bluetooth Version
- Bluetooth 5.2
- Bluetooth Profiles
- Hands-Free Profile (HFP), Headset Profile (HSP), Serial Port Profile (SPP), Advanced Audio Distribution Profile (A2DP), Audio/Video Remote Control Profile (AVRCP), Phonebook Access Profile (PBAP)
- Sound Output Mode
- Stereo
- 20 - 20000 Hz
- Max Input Power
- 30 mW
- Diaphragm
- 28 mm
- Simultaneously Connectable Devices Qty
- 2
- SafeTone technology, PeakStop technology, Jabra Direct, Jabra Xpress, Jabra Sound+
Microphone
- Boom
- Form Factor
- Headset microphone
- 3
- Sensitivity
- -38 dBV/Pascal
- 20 - 10000 Hz
Remote Control
- Controls
Cable
- Detachable Cable
Internet of Things (IoT)
- Internet of Things (IoT) Compatible
- Included Accessories
- Carrying pouch, USB-C charging cable, Jabra Link 390a USB Adapter
- Cable Details
- USB cable - detachable - 1.2 m
- Optimised for UC
- Plug and Play, G616
Sustainability Information
- TCO Certified
- Battery
- Handset battery rechargeable - Lithium Ion
- Run Time (Up To)
- 18 hour(s)
- Run Time Details
- Continuous playback (active noise-cancelling on): up to 15 hours , Continuous playback (active noise-cancelling off): up to 18 hours , Continuous talk (active noise-cancelling/busylight off): up to 16 hours , Continuous talk (active noise-cancelling/busylight on): up to 10 hours
- Recharge Time
- 2 hour(s)
- Limited warranty - 2 years
