Jabra Evolve2 55 Link 380 USB-A, MS Teams Stereo with Stand
Quicklinx: H9MSWS00 Mfr#: 25599-999-989
Recommended Use: Phone, Phone, Portable electronics, Computer
Connectivity: Wireless
Earcover : Binaural
More than 50 In Stock
£143.58 ex VAT
£172.29 inc VAT
Professional quality calls anywhere. Motivational playlists before an important presentation. Meditative sounds to help you focus. When you work in hybrid mode, your days can be very busy, so it's important that your headphones keep up with you.
The Evolve2 55 are specifically designed to go with you everywhere. They fit your every need, giving you a high-quality calling and music listening experience with Advanced Active Noise Cancellation, noise-canceling microphones and custom 28mm speakers, plus a high level of comfort with revolutionary Jabra Air Comfort technology.
  • Work-anywhere professionalism, with noise-cancelling microphone technology
    Work-anywhere professionalism, with noise-cancelling microphone technology.
Jabra Evolve2 55 MS Stereo - headset - with charging stand
Headset - Bluetooth - wireless - USB-A
Recommended Use
Portable electronics, phone, computer - communication
Headphones Form Factor
On-ear
Wireless
Wireless Technology
Bluetooth
Bluetooth Version
Bluetooth 5.2
Sound Output Mode
Stereo
Sound Effects
Power Bass
Audio Specifications
Frequency Response 20 - 20000 Hz
Max Input Power
30 mW
Active Noise Canceling
Microphone
Boom
Microphones Included
8
Controls
Mute, volume, power on/off, busylight, call
Software Certification
Zoom Certified, Cisco Webex Certified, Optimised for Microsoft Teams, Alcatel-Lucent Certified, Avaya Certified, Unify Certified, MFi Certified, Amazon Chime Certified
Bundled with
Charging stand
18.5 cm
17.5 cm
6.5 cm
130 g
Earpad Material
Leatherette, foam
Recommended Use
Multipoint Pairing, LED indicator, easy pairing, over the air updates
Protection
Hearing protection
Max Operating Distance
30 m
Bundled with
Charging stand
Audio Output
On-ear
Wireless
Wireless Technology
Bluetooth
Bluetooth Version
Bluetooth 5.2
Bluetooth Profiles
Hands-Free Profile (HFP), Headset Profile (HSP), Serial Port Profile (SPP), Advanced Audio Distribution Profile (A2DP), Audio/Video Remote Control Profile (AVRCP), Phonebook Access Profile (PBAP)
Sound Output Mode
Stereo
Sound Effects
Power Bass
Frequency Response
20 - 20000 Hz
Max Input Power
30 mW
Diaphragm
28 mm
Simultaneously Connectable Devices Qty
2
SafeTone technology, PeakStop technology, Jabra Direct, Google Fast Pair, Jabra Xpress, Jabra Sound+
Microphone
Boom
Headset microphone
8
Sensitivity
-38 dBV/Pascal
Frequency Response
20 - 10000 Hz
Remote Control
Controls
Cable
Detachable Cable
Carrying pouch, USB-C charging cable, Jabra Link 390a USB Adapter, desk stand
Cable Details
USB-C charge cable - detachable - 1.2 m
Plug and Play, G616
Handset battery rechargeable - Lithium Ion
Run Time (Up To)
18 hour(s)
Run Time Details
Continuous playback (active noise-cancelling on): up to 15 hours , Continuous playback (active noise-cancelling off): up to 18 hours , Continuous talk (active noise-cancelling/busylight off): up to 16 hours , Continuous talk (active noise-cancelling/busylight on): up to 10 hours
Recharge Time
2 hour(s)
Recommended Use: Portable electronics
Recommended Use: Computer
Earcover : Binaural
Brand: Jabra
