Is your contact center moving, or considering moving, to softphones? Are you investing in contact center platform - whether on-premise or cloud-based? The Jabra Engage 50 is the ideal digital headset to power your customer satisfaction.
The Jabra Engage 50 features a powerful processing chip in the earcup that delivers advanced functionality including call analytic data.
Work-anywhere professionalism, with noise-cancelling microphone technology
Work-anywhere professionalism, with noise-cancelling microphone technology.
- Jabra Evolve2 50 MS Stereo - headset - USB-A
- Product Type
- Headset - wired - USB-A
- Recommended Use
- Portable electronics, phone, computer - communication
- Black
- Headphones Form Factor
- On-ear
- Connectivity Technology
- Wired
- Bluetooth Version
- Bluetooth 5.2
- Sound Output Mode
- Stereo
- Sound Effects
- Power Bass, HD Voice
- Audio Specifications
- Frequency Response 20 - 20000 Hz
- Max Input Power
- 30 mW
- Active Noise Canceling
- Microphone
- Boom
- Microphones Included
- 4
- Controls
- Mute, volume, power on/off, busylight, call
- Environmental Standards
- TCO Certified Headsets 9
- Software Certification
- Zoom Certified, Certified for Microsoft Teams, Cisco Webex Certified, Alcatel-Lucent Certified, Unify Certified, Google Meet Certified, Amazon Chime Certified
- 2-year warranty
- Product Type
- 19.3 cm
- 17.5 cm
- 6.5 cm
- 148.9 g
- Black
- Earpad Material
- Leatherette, foam
- Recommended Use
- Multipoint Pairing, LED indicator, easy pairing, over the air updates
- Protection
- Hearing protection
- Max Operating Distance
- 30 m
Audio Output
- On-ear
- Wired
- Bluetooth Version
- Bluetooth 5.2
- Bluetooth Profiles
- Hands-Free Profile (HFP), Headset Profile (HSP), Serial Port Profile (SPP), Advanced Audio Distribution Profile (A2DP), Audio/Video Remote Control Profile (AVRCP), Phonebook Access Profile (PBAP)
- Sound Output Mode
- Stereo
- Sound Effects
- 20 - 20000 Hz
- Max Input Power
- 30 mW
- Diaphragm
- 28 mm
- Simultaneously Connectable Devices Qty
- 2
- SafeTone technology, PeakStop technology, Jabra Direct, Jabra Xpress
Microphone
- Boom
- Form Factor
- Headset microphone
- 4
- Sensitivity
- -38 dBV/Pascal
- 20 - 10000 Hz
Remote Control
- Controls
- Connector Type
- Headset (USB Type-A)
- Included Accessories
- Carrying pouch
- Cable Details
- USB cable - 1.7 m
- Plug and Play, G616
Sustainability Information
- TCO Certified
- Limited warranty - 2 years
