Jabra Evolve2 40 SE MS Stereo Wired USB-C
Quicklinx: J6DTWS00 Mfr#: 24189-999-899
Recommended Use: Phone, Computer, Phone
Connectivity: Wired
Earcover : Binaural
£84.42 ex VAT
£101.30 inc VAT
The Jabra Evolve2 40 SE MS Stereo headset is designed for professionals who require high-quality audio and seamless communication in their work environment. Featuring a boom microphone with noise-canceling capabilities and a frequency response tailored for both multimedia and communication, this headset delivers clear sound. Wired connectivity provides a stable connection without the concern of battery life, while intuitive controls allow for easy management of calls and music. Certified for Microsoft Teams, it integrates smoothly into your workflow, enhancing productivity. The inclusion of SafeTone technology ensures your hearing is protected during long hours of use. With its durable aluminum construction and comfortable design, the Jabra Evolve2 40 SE MS Stereo is a reliable companion for the modern professional.
  • Quiet delivered to your desk
    Put on your Evolve2 40 and feel the noise around you instantly fade, as the isolating foam oval ear cushions and pioneering new angled earcup design work to effectively block out your surroundings, giving you outstanding passive noise-cancellation. Instant quiet without leaving your desk. That's the new standard.
  • Don't hide when you're in your stride
    We've taken our busylight to a whole new level, making it visible from any direction. The red light is automatically activated when you're on a call or in a meeting or you can activate it yourself at the touch of a button. So, even when you're right in the middle of everything, your busylight will protect you from all angles, and all interruptions. It's like having a built-in security guard for your concentration.
  • You call the shots
    When you've got a lot to get through, seamless, professional calls are vital. So we took the incredible call performance of our world-leading Evolve Series and we made it even better, building in three strategically placed powerful professional microphones and adding our advanced digital chipset and latest signal processing technology. So when you need to make the call, your headset won't let you down.
  • UC-certified means UC-satisfied
    Satisfaction guaranteed isn't something you hear very often these days, but we're bringing it back; Evolve2 40 works with all leading Unified Communications (UC) platforms, for truly seamless collaboration. If your UC platform of choice is Microsoft Teams, the Teams-certified variant is perfectly adapted and optimised to give you the best experience with the platform.
  • Music matters
    We built this headset with powerful leak-tolerant 40mm speakers and powered it with our most advanced digital chipset ever. The Evolve Series brought you great music while you worked. Now, with Evolve2, we're levelling up the audio quality to bring you music like you've never heard. Sound good? You bet it does.
  • The new standard of comfort
    We set out to create a headset that would feel so great, you'd forget you were even wearing it. We designed the perfect shape using biometric measurements from hundreds of heads. Then we added soft memory foam cushions that mould to your ear's natural contours. Finally, we assembled it using durable, premium materials. We've taken comfort to a whole new level.
  • Thinking outside the box
    As far as things in boxes go, this is kind of a big deal. Before you've even unboxed it, you're holding a pioneering piece of tech that's leagues ahead of any other headset. But because we have one eye on the future, firmware upgrades and value packs are already on the way to boost it even further. If you think it's great now, just wait…
Jabra Evolve2 40 SE MS Stereo - headset - USB-C
Headset - wired - USB-C
Recommended Use
Phone, computer - communication
Headphones Form Factor
On-ear
Wired
Sound Output Mode
Stereo
Audio Specifications
Frequency Response 20 - 20000 Hz - Sensitivity 117 dB
Max Input Power
30 mW
Noise Isolating
Microphone
Boom
Microphone Noise Cancelling
Microphones Included
3
Controls
Mute, volume, answer/end, play/pause, next/previous track, flip-to-mute
Environmental Standards
TCO Certified Headsets 9
Software Certification
15.7 cm
6.05 cm
18.6 cm
188 g
Body Material
Aluminium
Headband Material
Foam, silicone
Earpad Material
Leatherette, foam
Recommended Use
Audio Output
On-ear
Wired
Bluetooth Audio Codec
SBC
Sound Output Mode
Stereo
Noise Isolating
Frequency Response
20 - 20000 Hz
Max Input Power
30 mW
Sensitivity
117 dB
Diaphragm
40 mm
Volume Limiting Function
Busy light, SafeTone technology, Jabra Direct, Jabra Xpress
Audio Output Details
Multimedia - 20 - 20000 , Communication - 100 - 14000
Microphone
Boom
Headset microphone
3
Sensitivity
-26 dBFS/Pa
Frequency Response
100 - 14000 Hz
Noise Cancelling
Remote Control
Controls
Connector Type
Headset (24 pin USB-C)
Soft pouch
Cable Details
Headset cable
Plug and Play, FSC
Sustainability Information
TCO Certified
Shipping Width
18.85 cm
Shipping Depth
5.5 cm
Shipping Height
21.7 cm
J6DT Jabra Ear Cushions for Evolve2 65/40 (6pcs) - Black In Stock £68.29
Recommended Use: Computer
Connectivity: Wired
Earcover : Binaural
Brand: Jabra
