Jabra Evolve2 30 SE USB-A MS Stereo
Quicklinx: HDGYWS00 Mfr#: 23189-999-979
Recommended Use: Phone, Phone, Computer
Connectivity: Wired
Earcover : Binaural
More than 50 In Stock
£65.23 ex VAT
£78.27 inc VAT
Engineered to keep you productive. Lightweight, portable, reliable, comfortable. It's time to get ahead with this standard of professionalism. From open office to open-plan living, Evolve2 30 opens doors to enhanced comfort, seamless collaboration and instant concentration anywhere, whoever you are and however you work. Work smarter with the Jabra Evolve2 30.
  • Engineered to keep you productive
    It's time to get ahead with the new standard of professionalism. From open office to open-plan living, Evolve2 30 opens doors to enhanced comfort, seamless collaboration and instant concentration anywhere, whoever you are and however you work. Work smarter with the new Jabra Evolve2 30.
  • Clear, collaborative calls
    When you're working flexibly, you need to know you can be heard clearly wherever you are. Our advanced 2-microphone audio system captures your voice while simultaneously analyzing and reducing the noise around you, meeting Microsoft Open Office requirements. The perfect way to get your point across and ensure even the smallest nuance isn't lost in translation. Evolve2 30 makes every call count.
  • Easy listening
    When time is of the essence, great quality audio is essential. With our professional-grade 28mm speakers and an advanced digital chipset, the Evolve2 30 delivers exceptional audio quality. So, whether you're taking an important call or listening to music while you work, you can enjoy great sound that's engineered for modern working. Hearing every detail has never been easier.
  • UC-certified means UC-satisfied
    'Satisfaction guaranteed' isn't something you hear very often these days, but we're bringing it back; Evolve2 30 works with all leading Unified Communications (UC) platforms, for truly seamless collaboration. If your UC platform of choice is Microsoft Teams, the Teams-certified variant is perfectly adapted and optimised to give you the best experience with the platform. UC, it's so easy.
  • Heavy on comfort
    To get ahead, we measured heads. Hundreds of them. Then we used that data to design the perfect shape using biometric measurements. The result is a headset that's been ergonomically designed to exert just the right amount of evenly distributed pressure and built with premium materials, with soft memory foam ear cushions that mould to your ears' natural contours. When you're in and out of calls all day, you need to know that your headset won't weigh you down. In fact, research suggests a well-fitting headset can significantly enhance your workday, extending your wearing time and improving your experience on calls and when listening to music. Settle into the new standard of comfort. You've earned it.
  • Thinking outside the box
    As far as things in boxes go, this is kind of a big deal. Before you've even unboxed it, you're holding a pioneering piece of tech that's leagues ahead of any other headset. But because we have one eye on the future, firmware upgrades and value packs are already on the way to boost it even further. Think it's great now? Just wait…
  • Shh… we're working
    Looking for a way to get some instant peace and quiet? Evolve2 30 is specifically designed to deliver portable concentration, with noise-isolating memory foam ear cushions and a pioneering angled earcup design. With this lightweight headset in your workbag, you're only ever a second away from being able to hear yourself think. Accessible concentration anywhere is the new standard.
  • Flexibility you can depend on
    From the office, to your home and even in your local coffee shop – when you work flexibly, your headset gets around almost as much as you do. We've re-engineered the design of the Evolve2 30 with a stainless-steel headband and slider for maximum durability. We've also significantly enhanced the design of the earcups, so internal and external components are more resistant to impact. Productive flexible working starts with reliable tools.
  • Do not disturb
    The Evolve2 30 automatically knows when you need peace and quiet. An integrated busylight turns on automatically when you're on a call and you can also turn it on manually to signal 'do not disturb' mode. Fewer interruptions; wherever your office is.
  • Unbox
    Instant collaboration is where it's at these days. Evolve2 30 is plug-and-play and available in both USB-A and USB-C variants, so you can unbox it and get going straight away. It really is that simple. No, really.
Jabra Evolve2 30 SE MS Stereo - headset
Headset - wired - USB-A
Recommended Use
Computer, phone - communication
Headphones Form Factor
On-ear
Wired
Sound Output Mode
Stereo
Audio Specifications
Frequency Response 20 - 20000 Hz - Sensitivity 115 dB
Max Input Power
30 mW
Noise Isolating
Microphone
Boom
Microphones Included
2
Controls
Play/pause, volume, next/previous track, mute, answer/end
Software Certification
Certified for Microsoft Teams
13.62 cm
5.43 cm
17.87 cm
125 g
Headband Material
Foam, leatherette, stainless steel
Earpad Material
Foam, leatherette
Recommended Use
Audio Output
On-ear
Wired
Sound Output Mode
Stereo
Noise Isolating
Frequency Response
20 - 20000 Hz
Max Input Power
30 mW
Sensitivity
115 dB
Diaphragm
28 mm
Busy light, Jabra Direct, Jabra Xpress, SafeTone technology
Audio Output Details
Multimedia - 20 - 20000 , Communication - 100 - 12000
Microphone
Boom
Headset microphone
2
Remote Control
Controls
Connector Type
Headset (4 PIN USB Type A)
Cable
Cable Length
1.5 m
Carrying pouch
Cable Details
Headset cable - 1.5 m
Plug and Play, G616
Shipping Width
17 cm
Shipping Depth
4 cm
Shipping Height
21.3 cm
Recommended Use: Computer
Connectivity: Wired
Earcover : Binaural
Brand: Jabra
