Jabra Evolve LINK USB UC Controller Only
Quicklinx: B95YWS00 Mfr#: 14208-04
24 in stock
£31.84 ex VAT
£38.20 inc VAT
The EVOLVE Link unit can be matched with your existing EVOLVE headset. This version of EVOLVE Link is optimized for unified communication.
  • Digital signal processing
    Digital signal processing is a technology that digitally optimizes your voice and music and suppresses echoes.
  • Noise cancel
    Enhances call clarity by eliminating background noise from the office.
  • Mute function
    Mute gives you the option to mute/unmute the microphone directly on the device.
  • Jabra PC suite
    Jabra PC suite enables remote call control with Jabra headsets and the generation of UC and IP softphones. Wireless headset users can answer and end calls away from their desk and softphone. With a corded headset, Jabra PC suite gives you a number of remote call control functions either directly from your headset or from in-line buttons on the cord. The seamless integration between headset and softphone allows users to benefit from enhanced mobility and the ability to multitask while on a call. This freedom improves work efficiency and ergonomics throughout the day.
JABRA EVOLVE Link UC remote control
Remote control
Cable
Supported Devices
Headphones / headsets
Evolve 40 UC mono, 40 UC stereo, 80 UC stereo
Remote control
Cable
Supported Devices
Volume control
Connector Type
1 x USB
Jabra Evolve 40 UC mono, 40 UC stereo, 80 UC stereo
Brand: Jabra
Price Range Ex VAT: 0 - 50
