Jabra Evolve Link MS Lync is a control unit with USB cable for Jabra Evolve 40 MS and Jabra Evolve 80 MS.
Effortless integration
Designed to seamlessly connect with headphones and headsets, the JABRA EVOLVE Link MS offers a Plug-and-Play experience via its USB connection. This feature ensures users can easily integrate the device into their existing setups without the need for complex installations or configurations. -
Intuitive control
The device comes equipped with a cable remote control, featuring volume control for easy adjustments. This allows users to manage their listening experience directly from the cable, providing a level of convenience and accessibility that enhances overall user satisfaction.
- JABRA EVOLVE Link MS remote control
- Remote control
- Connectivity Technology
- Cable
- Supported Devices
- Headphones / headsets
- Remote control
- Cable
- Supported Devices
- Volume control
- Connector Type
- 1 x USB
