MORE THAN HEADSETS, A WORKPLACE EVOLUTION
Jabra Evolve 80 is a professional headset that eliminates noise and helps you get in your concentration zone and focus. With smartphone connectivity you can take your concentration zone wherever you are going; work, at the office, at home, travelling or commuting. For calls or simply enjoying music.
UNRIVALLED NOISE CANCELLATION
Built to eliminate noise, Jabra's unique Active Noise Cancellation (ANC) filters out low-frequency background noise. Unique designed ear cushions block high-frequency sounds so you can enjoy your music or phone calls without distraction. Noise-cancelling microphone makes sure that you and the other party can hear each other loud and clear.
SIMPLE PLUG-AND-PLAY SETUP
Works straight out of the box with all leading UC systems. Installation is as easy as simply plugging it Into the USB port or 3.5mm jack to your laptop, or by using the 3.5mm jack straight into your smart device.
INTUITIVE CONTROL UNIT
Get easy access at your fingertips to the most used functions, like accept call, volume and mute.
SIGNAL YOUR AVAILABILITY
Whether you are on a call or working on a task needing your full attention, the Jabra EVOLVE™ 80 has an integrated busy light on the ear cups, letting people around you clearly see your availability. You can activate the red busy light to create your own concentration zone and keep you from being disturbed whenever equired. Evolve 80 makes a great travelling companion too in noisy airports and public environments for phone calls or for music and relaxation. You can take your concentration zone wherever you need to go.
More concentration, greater productivity
Shield disruptive background noise with superior active and passive noise-cancellation for crystal-clear calls and music. -
Stay in the zone and avoid interruptions
Superior ANC and an integrated busylight that notifies colleagues to avoid interruptions. -
Find inspiration in sound
Immersive music experience delivered by world-class speakers in a premium around-the-ear headset. -
All-day comfort
Leather-feel ear cushions and around-the-ear design for all-day use.
- Jabra Evolve 80 MS stereo - headset - 3.5 mm jack
- Product Type
- Headset - wired - 3.5 mm jack
- Recommended Use
- Portable electronics, computer - communication
- Headphones Form Factor
- Full size
- Foldable
- Connectivity Technology
- Wired
- Headphones Technology
- Dynamic
- Sound Output Mode
- Stereo
- Sound Effects
- PureSound
- Audio Specifications
- Frequency Response 20 - 20000 Hz
- Max Input Power
- 30 mW
- Active Noise Canceling
- Microphone
- Boom
- Controls
- Mute, volume, answer/end
- Software Certification
- Certified for Skype for Business
- Product Type
- Dimensions & Weight Details
- Headset: 19 cm 19 cm / 324 g , Control unit: 5.5 cm 5.5 cm / 57 g
- 19 cm
- 19 cm
- 324 g
- Earpad Material
- Leatherette
- Recommended Use
Audio Output
- Full size
- Foldable
- Dynamic
- Wired
- Sound Output Mode
- Stereo
- Sound Effects
- PureSound
- Active Noise Cancelling Technology
- Hybrid ANC
- 20 - 20000 Hz
- Max Input Power
- 30 mW
- Diaphragm
- 40 mm
- In-Cord Volume Control
- Busy light, Listen-in function
Microphone
- Boom
- Form Factor
- Headset microphone
Remote Control
- Controls
- Connector Type
- Headset (mini-phone stereo 3.5 mm 4-pole)
Cable
- Cable Length
- 1.2 m
- Included Accessories
- Carrying pouch, cord management clips
- Cable Details
- Headset cable - 1.2 m , USB control cable - detachable - 95 cm
- Plug and Play, UL, FCC, KCC, RCM
- Battery
- Headset battery rechargeable
- Recharge Time
- 2 hour(s)
- Shipping Width
- 21.5 cm
- Shipping Depth
- 21.5 cm
- Shipping Height
- 5.5 cm
- Shipping Weight
- 646 g
Jabra Earcushion, Leather For Jabra Evolve 80 - Pack 10 | In Stock | £11.97 |
Jabra USB-A to USB-C Adapter | In Stock | £15.16 |
