Jabra Evolve 75 is a great wireless headset for concentration in the open office. You can switch on active noise cancellation to virtually eliminate low-frequency sounds, like the hum of air conditioning. The high-quality speakers and HD voice ensure crystal-clear calls and music.
Shut out office noise and increase your productivity
You can switch on active noise-cancellation to virtually eliminate low-frequency sounds, such as the hum of air conditioning. Active noise-cancellation uses advanced microphones to monitor and counter ambient noise. -
Reduce noise and interruptions
Superior ANC and integrated busylight acts as a "do not disturb" sign to enhance productivity. -
All-day comfort
Leather-feel ear cushions and on-the-ear design for all-day use. -
More freedom
Dual Bluetooth connectivity to two devices at the same time for calls and music. Flexibility to move away from your connected device.
- Jabra Evolve 75 UC Stereo - headset
- Product Type
- Headset - Bluetooth - wireless - USB
- Recommended Use
- Portable electronics, conference
- Headphones Form Factor
- On-ear
- Connectivity Technology
- Wireless
- Wireless Technology
- Bluetooth
- Bluetooth Version
- Bluetooth 4.2
- Sound Output Mode
- Stereo
- Audio Specifications
- Frequency Response 20 - 20000 Hz
- Active Noise Canceling
- Microphone
- Boom
- Microphone Operation Mode
- Uni-directional
- Microphone Noise Cancelling
- Controls
- Mute, volume, on/off, answer/end
- 2-year warranty
- Product Type
- 17.6 cm
- 20.6 cm
- 5.1 cm
- 177 g
- Recommended Use
Audio Output
- On-ear
- Wireless
- Bluetooth
- Bluetooth Version
- Bluetooth 4.2
- Sound Output Mode
- Stereo
- 20 - 20000 Hz
- Diaphragm
- 40 mm
- In-Cord Volume Control
- Simultaneously Connectable Devices Qty
- 2
Microphone
- Boom
- Form Factor
- Headset microphone
- Uni-directional
- 150 - 6800 Hz
- Signal-to-Noise Ratio
- 17 dB
- Noise Cancelling
Remote Control
- Controls
- Connector Type
- Headset (4 PIN USB Type A)
- Included Accessories
- Protective case, Jabra Link 370 USB Adapter
- Cable Details
- USB cable - detachable
- Battery
- Headset battery rechargeable
- Run Time (Up To)
- 15 hour(s)
- Recharge Time
- 2.5 hour(s)
- Limited warranty - 2 years
