The best wireless headset for concentration in the open office
Block out noise and interruptions in the open office and stay focused on your tasks. Our professional wireless headset delivers amazing sound and superior Active Noise Cancellation.
The Evolve 75 is a wireless headset with superior Active Noise Cancellation and integrated busylight to enhance your productivity. Dual connectivity to two Bluetooth® devices allows you to take calls and listen to music from the same headset, giving you extra freedom to move 100ft/30m away from your smartphone and/or PC.
Outstanding sound for calls and music
HD voice for your calls and world class speakers for music.
Reduce noise and interruptions
Superior ANC and integrated busylight acting as a do not disturb signal
More freedom
Dual Bluetooth® connectivity to two devices at the same time for calls and music, with the flexibility to move up to 100feet/30 meters away from your connected device.
Wireless Bluetooth technology gives you up to 30 meters / 100 feet of hands-free connectivity to PC, smartphone and tablet. Up to 10 hours battery life eliminates battery concerns. Simply tap to connect devices with NFC. Dual connectivity enables you to connect your headset to your PC and one other Bluetooth device at the same time, so you can take the call on your preferred phone device. Busy light signals user availability. The microphone boom arm can be integrated into the headband when not on a call. Microphone mute on boom arm. Built for style and comfort with leatherette ear cushions. Soft pouch included.
World-class speakers and HD voice for crystal-clear calls and music. -
Superior ANC and integrated busylight acts as a 'do not disturb' sign to enhance productivity. -
More freedom
Dual Bluetooth connectivity to two devices at the same time for calls and music. Flexibility to move up to 100ft/30m away from your connected device.
- Jabra Evolve 75 MS Stereo - headset
- Product Type
- Headset - Bluetooth - wireless - USB
- Recommended Use
- Portable electronics, computer - communication
- Headphones Form Factor
- On-ear
- Connectivity Technology
- Wireless
- Wireless Technology
- Bluetooth
- Bluetooth Version
- Bluetooth 4.2
- Sound Output Mode
- Stereo
- Audio Specifications
- Frequency Response 20 - 20000 Hz
- Active Noise Canceling
- Microphone
- Boom
- Microphone Noise Cancelling
- Microphones Included
- 4
- Controls
- Mute, volume, on/off, answer/end
- Software Certification
- Certified for Skype for Business
- 2-year warranty
- Product Type
- 177 g
- Recommended Use
- Max Operating Distance
- 30 m
Audio Output
- On-ear
- Wireless
- Bluetooth
- Bluetooth Version
- Bluetooth 4.2
- Bluetooth Profiles
- Hands-Free Profile (HFP), Headset Profile (HSP), Advanced Audio Distribution Profile (A2DP), Audio Gateway Hands-Free Profile (AGHFP)
- Sound Output Mode
- Stereo
- 20 - 20000 Hz
- Diaphragm
- 40 mm
- In-Cord Volume Control
- Simultaneously Connectable Devices Qty
- 2
- Busy light
Microphone
- Boom
- Form Factor
- Headset microphone
- 4
- 100 - 10000 Hz
- Signal-to-Noise Ratio
- 17 dB
- Noise Cancelling
- Audio Input Details
- Uni-directional - 100 - 10000 Hz
Remote Control
- Controls
- Connector Type
- Headset (4 PIN USB Type A)
- Included Accessories
- Protective case, Jabra Link 370 USB Adapter
- Cable Details
- USB cable - detachable
- Battery
- Headset battery rechargeable
- Run Time (Up To)
- 18 hour(s)
- Standby Time
- 360 hours
- Recharge Time
- 2 hour(s)
- Limited warranty - 2 years
Jabra Link 370 USB Bluetooth Adapter | In Stock | £49.21 |
Jabra Link 370 USB Bluetooth Adapter for MS | In Stock | £48.47 |
Jabra Link 370 USB BT Adapter, MS Teams | In Stock | £41.62 |
